Ana içeriğe geç
Samsung Galaxy S7 Edge Rear Camera Lens Replacement
Neye ihtiyacın var
    • Follow this procedure if you are replacing only the glass lens over the rear-facing camera.
    • If you are replacing the entire bezel, skip this step and follow the instructions in the next step.
    • Follow this longer procedure to replace the bezel and camera lens, which are installed on the rear case.
    • If you follow this procedure, you will need new adhesive to reinstall the rear case. Follow this guide to reinstall the camera bezel adhesive as well as the rear cover adhesive.
Bitiş Çizgisi
16 farklı kişi bu kılavuzu tamamladı.
Evan Noronha
221.656 İtibar
168 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 41
Her zaman: 22,001
