Ana içeriğe geç
Samsung Galaxy S8 Plus Display Adhesive Replacement
Neye ihtiyacın var
  1. Samsung Galaxy S8 Plus Display Adhesive Replacement, Display Adhesive: adım 1, 3 resimden 1. Samsung Galaxy S8 Plus Display Adhesive Replacement, Display Adhesive: adım 1, 3 resimden 2. Samsung Galaxy S8 Plus Display Adhesive Replacement, Display Adhesive: adım 1, 3 resimden 3.
    • Remove all traces of adhesive and debris from the phone's frame. Clean the adhesion surface with high concentration isopropyl alcohol (over 90%) and wipe it clean with a lint-free cloth.
    • If glue or glass remnants are left behind, the new display will not mount correctly and may be damaged.
    • Lay the adhesive strips out to get an idea of where they go.
    • Peel off the clear plastic backing from the large pre-cut adhesive strip, exposing one side of adhesive.
  2. Samsung Galaxy S8 Plus Display Adhesive Replacement: adım 2, 3 resimden 1. Samsung Galaxy S8 Plus Display Adhesive Replacement: adım 2, 3 resimden 2. Samsung Galaxy S8 Plus Display Adhesive Replacement: adım 2, 3 resimden 3.
    • Carefully line up a long edge of the adhesive with the edge of the phone frame.
    • Make sure that the adhesive cutouts match the phone's.
    • Set the adhesive down lightly on the frame.
    • If it is not properly aligned, carefully peel the adhesive back up.
    • Once the adhesive is aligned, use your fingers to press the adhesive onto the frame.
  3. Samsung Galaxy S8 Plus Display Adhesive Replacement: adım 3, 3 resimden 1. Samsung Galaxy S8 Plus Display Adhesive Replacement: adım 3, 3 resimden 2. Samsung Galaxy S8 Plus Display Adhesive Replacement: adım 3, 3 resimden 3.
    • Peel one of the end adhesive strips from the clear plastic backing.
    • The strips are cut for a specific end and are not interchangeable.
    • Hold the strip by the two green end tabs and line the adhesive strip with the phone frame.
    • Lay the adhesive down lightly on the phone. Make sure that all cutouts are properly aligned.
    • Once aligned, use your fingers to press the adhesive into place.
    • Repeat the procedure for the remaining adhesive strip.
  4. Samsung Galaxy S8 Plus Display Adhesive Replacement: adım 4, 1 resimden 1.
    • Continue reassembling your device until you are ready to attach the screen.
    • If possible, test your screen's functionality before sticking it in place.
    • Peel and remove the green plastic liner from all adhesive strips to expose the screen-facing adhesive.
    • Align and set the phone screen on top of the adhesive.
    • Use your fingers to squeeze around the perimeter of the phone to set the adhesive.
    • Apply a few books worth of weight on top of the screen for an hour to help the adhesive bond.
Sonuç
Follow this link to return to the Galaxy S8+ screen replacement guide.
10 farklı kişi bu kılavuzu tamamladı.
Arthur Shi
283.805 İtibar
587 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.674 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 58
Her zaman: 6,577
