Giriş
Cracked screen? Touch not working? Bad OLED display? This video guide will help you open your Galaxy S8+ and transplant the internals into a new frame, with a new screen already attached. This can sometimes be easier than replacing the screen by itself. Note that the video is narrated in German, but the steps are clearly demonstrated and you should be able to follow along without too much difficulty regardless of language.
Note that this repair involves removing the battery. Once removed, the battery should not be re-used (it's a potential fire safety hazard and can damage your phone). Have a replacement battery ready before starting this repair.
Note: Some replacement screens are sold without the frame attached. In that case, follow this guide instead.
Neye ihtiyacın var
Video talimatları
34 farklı kişi bu kılavuzu tamamladı.
5 Yorum
something to note, not sure if the guy mentions in video (it’s german, I didn't actually watch it) :
If you try and test the new display before you reassembled the mid frame, you will get a temperature warning. reinstall all screws and mid frame then test, should be good.
also, this is the only method you should attempt this repair, as the official samsung screens will come like this, with frame. If not, its not original, don’t waste your time or money on sh!tty parts
Andrew - Yanıt
Agreed! I love my OEM Samsung Service Box Display
Ethan Bain - Yanıt
Best video I’ve seen of the S8 teardown. Agree with what Andrew said above, check the midframe to see all the extra small parts are there. To check everything works, you can turn on the phone with after connecting the display to the motherboard, and puting the internals back together (everything but gluing the front and back pieces). Be careful to put all the screws back in place- the motherboard needs a tight connection to components on the midframe (like the power button and audio speaker) to work. Good luck!
Michael M - Yanıt
Can I buy the screen replacement
Christian lares - Yanıt
How can i by samsung Galaxy 8+ screen?
Nguse Hayelom - Yanıt
