Ana içeriğe geç
Samsung Galaxy S8 Plus SIM Card or SD Card Replacement
Görüntüleme: 21 B
İstatistikleri görüntüle:
Son 24 Saat:
9
Son 7 Gün:
38
Son 30 Gün:
150
Her zaman:
21.152
Yorumlar: 1
1 comment on steps.
Tamamlandı: 6
6 kişi bu kılavuzu "tamamlandı" olarak işaretledi. Sıradaki sen olacak mısın?
Sık Kullanılanlar: 1
1 kişi bu kılavuzu favorilerine ekledi (ve abone oldu). Sıradaki sen olacak mısın?
Gerekli Süre: 1 dakika
Zorluk: Kolay
The SIM card tray houses both the SIM card for your cellular network as well as the (optional) SD card for expanded storage. Use this guide to eject the tray and remove or replace either card. The S8 and S8+ both use the same tray, so the same part is compatible with either phone.
Neye ihtiyacın var
Parçalar
Aletler
    1. Samsung Galaxy S8 Plus SIM Card or SD Card Replacement, SIM Card or SD Card: adım 1, 2 resimden 1. Samsung Galaxy S8 Plus SIM Card or SD Card Replacement, SIM Card or SD Card: adım 1, 2 resimden 2.
      • The SIM card tray's ejection hole looks almost exactly like the microphone hole, located just a short distance away. Insert your tool only where indicated. Inserting your tool into the microphone hole may result in permanent microphone damage.
      • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray, on the top edge of the phone.
      • Press firmly to eject the tray.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Galaxy S8 Plus SIM Card or SD Card Replacement: adım 2, 2 resimden 1. Samsung Galaxy S8 Plus SIM Card or SD Card Replacement: adım 2, 2 resimden 2.
      • Grab the tray and pull straight out to remove it.
      • SIM and/or SD cards will fall out of the tray easily.
      • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
      • A thin rubber gasket near the outer end of the SIM tray provides water and dust protection. If this gasket is damaged or missing, replace the gasket to protect your phone's internal components.
      FixBot'a Sor
      Yorum Ekle
Sonuç
After you've completed the repair, follow this guide to test your repair.
6 farklı kişi bu kılavuzu tamamladı.
Yazar
ile
Jeff Suovanen
455.632 İtibar
259 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
119 Üyeler
72.955 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 38
Son 30 gün: 150
Her zaman: 21,152
