Ana içeriğe geç
Samsung Galaxy S9 Back Cover Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. Samsung Galaxy S9 Back Cover Replacement, Back Cover: adım 1, 1 resimden 1.
    • Heat the iOpener in the microwave for 30-60 seconds.
    • Apply the iOpener to the backside edge and let it sit for 2-3 minutes.
  2. Samsung Galaxy S9 Back Cover Replacement: adım 2, 1 resimden 1.
    • Press the suction handle firmly on to the back cover.
    • Insert an opening pick between the back cover and the device's body while pulling upwards on the suction handle.
  3. Samsung Galaxy S9 Back Cover Replacement: adım 3, 2 resimden 1. Samsung Galaxy S9 Back Cover Replacement: adım 3, 2 resimden 2.
    • Apply more opening picks to the edges of the phone, heating the other sides as needed.
    • Be patient. This step requires quite a bit of work. The adhesive is difficult to melt, making it time-consuming to remove the back of the phone.
    • Because the back panel is made of glass, inserting and sliding the opening picks is likely to crack the glass. If the glass does shatter, please cover it with packing tape to protect your hands from the sharp edges and fragments.
  4. Samsung Galaxy S9 Back Cover Replacement: adım 4, 3 resimden 1. Samsung Galaxy S9 Back Cover Replacement: adım 4, 3 resimden 2. Samsung Galaxy S9 Back Cover Replacement: adım 4, 3 resimden 3.
    • Use the iFixit opening tool to separate the back cover from the rest of the device.
  5. Samsung Galaxy S9 Back Cover Replacement: adım 5, 1 resimden 1.
    • Remove the back cover.
Sonuç
Ani Svadjian
925 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G6, White Winter 2019 Cal Poly, Team S1-G6, White Winter 2019 üyesi
CPSU-WHITE-W19S1G6
4 Üyeler
29 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 74
