Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
The earpiece speaker is the speaker that outputs sound at the top of the device. This speaker is enabled when you receive phone calls. Be sure to check our troubleshooting page to see if the problem is within the software of the device.
If the problem happens to be within the actual hardware of the device then follow this guide to replace the earpiece speaker.
Be forewarned- replacing this part involves breaking your phone's waterproof seal. If you want your phone to keep its waterproof capabilities, you will need to replace the seal.
Neye ihtiyacın var
Before you begin, switch off your phone.
Apply a heated iOpener to a long edge of the phone to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes.
Press a suction cup onto the back cover.
Lift the back cover's bottom edge with your suction cup, opening a slight gap between the back cover and the frame.
Insert an opening pick in the gap you created and slide it to the bottom right corner.
Insert a second opening pick and slide it to the bottom left corner.
Insert a third opening pick to prevent the adhesive from resealing during the rest of the removal procedure.
Remove the earpiece speaker by prying it off of the front display with the spudger.
10 farklı kişi bu kılavuzu tamamladı.
3 Yorum
Replaced ear speaker but ended up being a software issue ☹️
So do you have a software issue now, or did you not need to replace the earpiece speaker? Asking so I can help troubleshoot if necessary.
Hey, I just replaced the earpiece speaker as well and it does not work in phone calls, however, it does work to play music. I’m not sure what the issue could be here besides software related issues, however, I will try to reset the phone and let you guys know if that fixes it. If anyone has any ideas, I’m all ears.
