Giriş
Use this guide to remove the fingerprint sensor and the camera lens cover in the Samsung Galaxy S9+.
Opening the Samsung Galaxy S9+ will damage the waterproof sealing on the device. If you do not replace the adhesive seals, your phone will function normally, but will loose its water-protection.
You’ll need replacement adhesive to reattach components when reassembling the device.
Neye ihtiyacın var
Switch off your phone.
Use an iOpener to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes. You might want to repeat this step several times during the back cover removal.
Start to slide the tip of the opening pick from the bottom left corner along the side of the S9 Plus.
Leave the opening pick in its place after you cut the adhesive half way up the left side of the phone.
Slide the opening pick from the bottom right corner half way up the frame and leave it there.
Apply a heated iOpener to the rear camera lens cover. Apply the iOpener for at least two minutes.
Secure the new back cover with pre-cut adhesive or double-sided adhesive tape.
After installing the rear cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
After you've completed the repair, follow this guide to test your repair.
14 farklı kişi bu kılavuzu tamamladı.
