Ana içeriğe geç
Samsung Galaxy SIII Mini Camera Failed Troubleshooting
Neye ihtiyacın var
Videoya Genel Bakış
  1. Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Camera Data and Cache: adım 1, 3 resimden 1. Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Camera Data and Cache: adım 1, 3 resimden 2. Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Camera Data and Cache: adım 1, 3 resimden 3.
    • Go to:
    • > Settings
    • > Application manager
    • > All
    • >Camera
    • Clear data and cache and check that the camera works. If no, go to the next step.
  2. Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Factory / Hard Reset: adım 2, 3 resimden 1. Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Factory / Hard Reset: adım 2, 3 resimden 2. Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Factory / Hard Reset: adım 2, 3 resimden 3.
    • Go to:
    • > Settings > Backup and reset
    • > Factory data reset
    • > Reset device > Erase everithing
    • !!! This will erase all your data !!!
    • For a Hard reset using hardware keys, follow this manual:
    • Samsung Galaxy - Wipe data/Factory reset
  3. Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Firmware: adım 3, 3 resimden 1. Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Firmware: adım 3, 3 resimden 2. Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Firmware: adım 3, 3 resimden 3.
    • Open sammobile and make an registration.
    • Search the firmware for your model and find the variant, corresponding to your mobile phone.
    • You can see the variant from Settings > About the device, or from dialer app by entering *#1234#
    • In the download page you can find instructions and link to the Odin app.
  4. Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Reconnecting Camera: adım 4, 3 resimden 1. Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Reconnecting Camera: adım 4, 3 resimden 2. Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Reconnecting Camera: adım 4, 3 resimden 3.
    • Switch off the phone and remove the battery and any SIM and memory card.
    • Remove the Midframe.
    • Disconnect the Menu buttons and the SD card reader flex cables.
    • Lift the board slightly to the left side and be careful with the earpiece and the main camera - they are stuck to the Display frame.
  5. Samsung Galaxy SIII Mini Camera Failed Troubleshooting: adım 5, 3 resimden 1. Samsung Galaxy SIII Mini Camera Failed Troubleshooting: adım 5, 3 resimden 2. Samsung Galaxy SIII Mini Camera Failed Troubleshooting: adım 5, 3 resimden 3.
    • Disconnect the LCD Display flex cable.
    • Open the camera flex cable connector and reconnect the camera.
  6. Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Camera Replacement: adım 6, 3 resimden 1. Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Camera Replacement: adım 6, 3 resimden 2. Samsung Galaxy SIII Mini Camera Failed Troubleshooting, Camera Replacement: adım 6, 3 resimden 3.
    • If the camera still does not work, the last step is camera replacement.
  7. Samsung Galaxy SIII Mini Camera Failed Troubleshooting: adım 7, 1 resimden 1.
    • Did you do it successfully?
Sonuç
16 farklı kişi bu kılavuzu tamamladı.
ZFix
194.222 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
327 Üyeler
1.673 adet Kılavuz yazıldı
3Kılavuz Yorumları
I did it! I did it! I did it!
I save time and money!
Thank you sooooo much!
Batis Kaf - Yanıt
how did you do it?!
zohny.omar -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 15
Her zaman: 9,664
