Ana içeriğe geç
Samsung Galaxy SIII Mini VE Battery Replacement
Neye ihtiyacın var
  1. Samsung Galaxy SIII Mini VE Battery Replacement, Removing Rear Casing: adım 1, 3 resimden 1. Samsung Galaxy SIII Mini VE Battery Replacement, Removing Rear Casing: adım 1, 3 resimden 2. Samsung Galaxy SIII Mini VE Battery Replacement, Removing Rear Casing: adım 1, 3 resimden 3.
    • Flip the phone over so you are viewing the back.
    • Using you fingernail, or an opening tool, pry open the notch that is located at the top of the phone.
    • Carefully follow you finger or opening tool around the edge of the rear casing until it has detached from the phone.
    • Set the rear casing aside for future use.
  2. Samsung Galaxy SIII Mini VE Battery Replacement, Removing the Battery: adım 2, 2 resimden 1. Samsung Galaxy SIII Mini VE Battery Replacement, Removing the Battery: adım 2, 2 resimden 2.
    • The battery is the large grey and black rectangle.
    • Using your fingernail, or opening tool, gently pry the bottom of the battery until it pops out.
    • Place the old battery aside for now, or dispose of it properly.
  3. Samsung Galaxy SIII Mini VE Battery Replacement, Inserting New Battery: adım 3, 2 resimden 1. Samsung Galaxy SIII Mini VE Battery Replacement, Inserting New Battery: adım 3, 2 resimden 2.
    • Locate your new battery.
    • Correctly orient the new battery to be inserted.
    • To orient the battery, make sure the 3 metallic bars align with the 3 prongs on the phone.
    • Gently insert the new battery into the battery slot.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Megan
1.228 İtibar
6 adet Kılavuz yazıldı
Ekip
Michigan Tech, Team 1-8, Lauer Fall 2014 Michigan Tech, Team 1-8, Lauer Fall 2014 üyesi
MTU-LAUER-F14S1G8
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 20
Her zaman: 3,475
