Ana içeriğe geç
Samsung Galaxy SIII Mini VE Front Camera Replacement
Neye ihtiyacın var
  1. Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Rear Casing: adım 1, 3 resimden 1. Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Rear Casing: adım 1, 3 resimden 2. Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Rear Casing: adım 1, 3 resimden 3.
    • Flip your phone so you are facing the back.
    • Locate the notch at the top and gently use your finger or an opening tool to remove the rear casing.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Battery: adım 2, 2 resimden 1. Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Battery: adım 2, 2 resimden 2.
    • Use your finger or an opening tool to pry the battery out of the phone.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Screws: adım 3, 1 resimden 1.
    • Use the Phillips #000 Screwdriver to remove the 10, 4mm screws holding the plastic frame in place.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung Galaxy SIII Mini VE Front Camera Replacement: adım 4, 2 resimden 1. Samsung Galaxy SIII Mini VE Front Camera Replacement: adım 4, 2 resimden 2.
    • Using an opening tool, gently separate the plastic framing from the phone.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Circuit Board: adım 5, 3 resimden 1. Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Circuit Board: adım 5, 3 resimden 2. Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Circuit Board: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Unhook the two electrical connections at the bottom of the phone using your fingernail or a spudger.
    • Next, use the spudger and tweezers to remove the speaker at the top of the phone.
    • Once the 3 components have detached, the circuit board should release from the phone except for 1 connection on the underside.
    • Detach this connection using the spudger.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Front Camera: adım 6, 3 resimden 1. Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Front Camera: adım 6, 3 resimden 2. Samsung Galaxy SIII Mini VE Front Camera Replacement, Removing Front Camera: adım 6, 3 resimden 3.
    • Locate the front camera connection.
    • Using the tweezers, lift the holding tab at the base of the ribbon wire.
    • Again, using the tweezers, gently pull the front camera out and away from the phone.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Megan
1.255 İtibar
6 adet Kılavuz yazıldı
Ekip
Michigan Tech, Team 1-8, Lauer Fall 2014 Michigan Tech, Team 1-8, Lauer Fall 2014 üyesi
MTU-LAUER-F14S1G8
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 5
Son 30 gün: 18
Her zaman: 1,479
