Ana içeriğe geç
Samsung Galaxy Sol Rear Camera Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Sol Rear Camera Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the back case of the phone by using an opening tool or fingernail to lift the divot on the top left side.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung Galaxy Sol Rear Camera Replacement: adım 2, 1 resimden 1.
    • Remove the battery by lifting from the bottom up with an opening tool or a small flat tool such as a credit card.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung Galaxy Sol Rear Camera Replacement, Rear Camera: adım 3, 1 resimden 1.
    • Remove the grey back of the phone by unscrewing all ten 0.4mm screws with a Phillips #00 screw bit.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung Galaxy Sol Rear Camera Replacement: adım 4, 1 resimden 1.
    • After you have removed all the screws, take a credit card or plastic tool to lift the screen. You will go all around the border of the phone.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung Galaxy Sol Rear Camera Replacement: adım 5, 3 resimden 1. Samsung Galaxy Sol Rear Camera Replacement: adım 5, 3 resimden 2. Samsung Galaxy Sol Rear Camera Replacement: adım 5, 3 resimden 3.
    • After removing the grey part of the phone, you will need to remove the motherboard by detaching all the chips.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung Galaxy Sol Rear Camera Replacement: adım 6, 1 resimden 1.
    • Once you detach the chips, remove the hard drive to access the rear camera.
    FixBot'a Sor
    Yorum Ekle
  7. Samsung Galaxy Sol Rear Camera Replacement: adım 7, 2 resimden 1. Samsung Galaxy Sol Rear Camera Replacement: adım 7, 2 resimden 2.
    • To remove the rear camera, flip the tab upward and then pull the camera straight out.
    FixBot'a Sor
    Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 27
Her zaman: 759
