Ana içeriğe geç
Samsung Galaxy Sol Speaker Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Sol Speaker Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the back case of the phone by using an opening tool or fingernail to lift the divot on the top left side.
  2. Samsung Galaxy Sol Speaker Replacement: adım 2, 1 resimden 1.
    • Remove the battery by lifting from the bottom up with an opening tool or a small flat tool such as a credit card.
  3. Samsung Galaxy Sol Speaker Replacement, Speaker: adım 3, 1 resimden 1.
    • Remove all ten 0.4mm screws by unscrewing them with the Phillips #00 screwdriver. After this, you will be able to lift up and remove the grey plastic piece.
  4. Samsung Galaxy Sol Speaker Replacement: adım 4, 1 resimden 1.
    • This is the speaker that you will be removing in the next step.
  5. Samsung Galaxy Sol Speaker Replacement: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Using the curved tweezers, grab ahold of the gold piece of the speakers and slowly lift out of the speaker slot.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 409
