Ana içeriğe geç
Samsung Galaxy Sol Speaker Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Sol Speaker Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the back case of the phone by using an opening tool or fingernail to lift the divot on the top left side.
  2. Samsung Galaxy Sol Speaker Replacement: adım 2, 1 resimden 1.
    • Remove the battery by lifting from the bottom up with an opening tool or a small flat tool such as a credit card.
  3. Samsung Galaxy Sol Speaker Replacement, Speaker: adım 3, 1 resimden 1.
    • Remove all ten 0.4mm screws by unscrewing them with the Phillips #00 screwdriver. After this, you will be able to lift up and remove the grey plastic piece.
  4. Samsung Galaxy Sol Speaker Replacement: adım 4, 1 resimden 1.
    • This is the speaker that you will be removing in the next step.
  5. Samsung Galaxy Sol Speaker Replacement: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Using the curved tweezers, grab ahold of the gold piece of the speakers and slowly lift out of the speaker slot.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 440
