Ana içeriğe geç
Samsung Galaxy Star Pro Screen Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Star Pro  Screen Replacement, Battery Replacement: adım 1, 1 resimden 1.
    • Place phone firmly between both hands with one hand flat on the back of the phone and pop off the back cover
    FixBot'a Sor
    Yorum Ekle
  2. Samsung Galaxy Star Pro  Screen Replacement: adım 2, 2 resimden 1. Samsung Galaxy Star Pro  Screen Replacement: adım 2, 2 resimden 2.
    • Once rear cover is off use small pastic spudger to lift battery out of the phone
    FixBot'a Sor
    Yorum Ekle
  3. Samsung Galaxy Star Pro  Screen Replacement, Screen: adım 3, 1 resimden 1.
    • After following how to remove the battery, unscrew the five 1.2mm Phillips Screws on the one back of the phone using screw driver. Use the J00 Phillips head screw bit to take out the screws
    FixBot'a Sor
    Yorum Ekle
  4. Samsung Galaxy Star Pro  Screen Replacement: adım 4, 1 resimden 1.
    • Once screws are removed turn the phone over and use the plastic opening tool and unclip the connector holding the screen to the motherboard.
    • Be careful to not damage the press-fit connector that connects the screen to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung Galaxy Star Pro  Screen Replacement: adım 5, 1 resimden 1.
    • Us the plastic opening tool to pry apart the screen from the plastic. Start from one side and work your way around the whole phone.
    FixBot'a Sor
    Yorum Ekle
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Victor bader
496 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 7-2, Catania Spring 2016 UMass Dartmouth, Team 7-2, Catania Spring 2016 üyesi
UMASSD-CATANIA-S16S7G2
3 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 23
Her zaman: 2,117
