Ana içeriğe geç
Giriş
This guide will teach you how to remove the back cover from your tablet, a prerequisite step to the other guides.
Parçalar
Hiçbir parça belirtilmedi.
  1. The plastic opening tool may break during this step. You may need to use the heavy duty spudger instead. Insert the plastic opening tool between the glass screen and the back cover so the curved end of the plastic opening tool is under the glass. Gently pry the back cover away from the glass screen.
    • The plastic opening tool may break during this step. You may need to use the heavy duty spudger instead.
    • Insert the plastic opening tool between the glass screen and the back cover so the curved end of the plastic opening tool is under the glass. Gently pry the back cover away from the glass screen.
    • Be sure to lift the entire display from the body and that you are not are lifting the glass from the display. You will need to reach down a little further for the correct removal.
    • Continue inserting the plastic opening tool around the whole device screen to completely separate the back cover from the glass screen.
  2. Gently lift the screen up with your finger. If the screen will not separate from the back cover, try repeating step 1.
    • Gently lift the screen up with your finger.
    • If the screen will not separate from the back cover, try repeating step 1.
Sonuç
Gabriel Rodarte
387 İtibar
2 adet Kılavuz yazıldı
Takım
Cal Poly, Team 6-26, Amido Winter 2015 Cal Poly, Team 6-26, Amido Winter 2015 üyesi
CPSU-AMIDO-W15S6G26
5 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 171
