Giriş
If your Samsung Galaxy Tab 2 10.1 tablet does not turn on (even after being charged) or the battery does not last as long as it used to, the battery may need to be replaced.
This guide demonstrates how to replace the battery in your tablet.
Caution: Some images display the steps using a metal spudger. Use the heavy-duty spudger instead to avoid damaging your circuits.
For more information on connectors, visit this page.
Neye ihtiyacın var
Insert the plastic opening tool between the glass screen and the back cover so the curved end of the plastic opening tool is under the glass. Gently pry the back cover away from the glass screen.
Be sure to lift the entire display from the body and that you are not are lifting the glass from the display. You will need to reach down a little further for the correct removal.
Continue inserting the plastic opening tool around the whole device screen to completely separate the back cover from the glass screen.
Using your fingers, remove the green tape covering the battery connector.
Insert the flat end of the heavy-duty spudger between the wires and underneath the battery connector. Carefully lift the black battery connector up to disconnect it from the motherboard.
Using your fingers, remove the green tape holding the three ribbon cables down.
Using the flat end of the heavy-duty spudger, carefully lift the black tab that holds the leftmost, black ribbon cable in place. Repeat this step for the gold ribbon cable and the black ribbon cable.
Using your fingers, gently slide each of the three cables straight out of the connectors.
56 farklı kişi bu kılavuzu tamamladı.
9 Yorum
I changed my battery and also the charging port/ribbon cable..... Could someone help me figure out why it still won't show anything on screen or turn on ? It's never been dropped, started having a problem with charging issues so decided it must be battery, port, or charger. So I bought all three and still no change ? help!!
Sorry I don't have any help for you, but it sounds like I am having the same issue as you. Please let me know if you solve your problem.
Does this really work?
Hello KW
Please go through in service manaula available on net and follow step by step like as
1- if have battery voltage more than 3.7 it meas your battery is OK and then go next step
2- check conenctor FPCB(SLC500) is fixed properly.
3- check voltage on ZD500 volagte when you press the on -off swicth ZD500 Voltage
have to same V_BATT voltage if no then replace power swicth .
4- Please Check U700(PMIC) and Power
on voltage(C760≥1.0V, C758≥
1.1V, C757≥1.0V, C755≥1.0V,
C754≥1.2V, C753≥1.35V,
C752≥2.0V) if volagte is not OK then replace U 7000.
good luck
