Ana içeriğe geç
Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement, Auxiliary Port: adım 1, 1 resimden 1.
    • Using a nylon spudger or flat plastic opening tool, pry open the back of the device.
    • It is easy to begin this process by starting at the micro SD card insert.
  2. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: adım 2, 1 resimden 1.
    • Using a Phillips head screwdriver, remove the 6 4mm screws holding holding the battery on the device.
  3. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: adım 3, 3 resimden 1. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: adım 3, 3 resimden 2. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: adım 3, 3 resimden 3.
    • Gently detach the set of wires clips connecting the battery to the device using a nylon spudger.
    • Remove the battery and set it aside.
  4. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: adım 4, 1 resimden 1.
    • Using a Phillips head screwdriver, remove the 6 4mm screws holding the motherboard in the device.
  5. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: adım 5, 3 resimden 1. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: adım 5, 3 resimden 2. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: adım 5, 3 resimden 3.
    • Locate the flex cables attached to the motherboard. Using a nylon spudger, gently detach each flex cable from the motherboard.
    • Be careful when detaching flex cables. Excessive force and sharp tools have the potential to damage these components.
    • Lift the motherboard from the device and set it aside.
  6. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: adım 6, 3 resimden 1. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: adım 6, 3 resimden 2. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: adım 6, 3 resimden 3.
    • Locate the yellow brackets at the bottom of the device.
    • Using a phillips head screwdriver, remove the single 4mm screw on each bracket, located on either side of the auxiliary port.
    • Lift the brackets from the device and set them aside.
    • You may need to use a nylon spudger, or any flat tool, to lift the brackets out of their place.
  7. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: adım 7, 1 resimden 1.
    • Using a nylon spudger, or any flat tool, gently pry and lift the small metal covering off of the auxiliary port.
    • This will reveal a rubber covering.
  8. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: adım 8, 1 resimden 1.
    • Using a nylon spudger, or any flat tool, gently pry and lift the small rubber covering to expose the auxiliary port.
    • This will reveal the auxiliary port.
  9. Samsung Galaxy Tab 2 7.0 Auxiliary Port Replacement: adım 9, 1 resimden 1.
    • Lift the auxiliary port with a nylon spudger.
    • Remove the auxiliary component.
    • It is easiest to lift this piece from the innermost side of the port, opposite of the opening.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Katija Tarailo
460 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S3-G1, Harley Spring 2017 IUPUI, Team S3-G1, Harley Spring 2017 üyesi
IUPUI-HARLEY-S17S3G1
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 15
Her zaman: 2,075
