Ana içeriğe geç
Samsung Galaxy Tab 2 7.0 Camera Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Tab 2 7.0 Camera Replacement, Camera: adım 1, 1 resimden 1.
    • Using a nylon spudger or a flat plastic opening tool, pry open the back of the device.
    • It is easiest to begin this process by starting at the micro SD card insert, as shown in the pictures.
  2. Samsung Galaxy Tab 2 7.0 Camera Replacement: adım 2, 1 resimden 1.
    • Using a phillips head screwdriver, remove the 6 4mm screws holding the battery on the device.
    • Remove the battery, and set it aside.
  3. Samsung Galaxy Tab 2 7.0 Camera Replacement: adım 3, 1 resimden 1.
    • Using a phillips head screwdriver, remove the 6 4mm screws holding the motherboard in the device.
  4. Samsung Galaxy Tab 2 7.0 Camera Replacement: adım 4, 3 resimden 1. Samsung Galaxy Tab 2 7.0 Camera Replacement: adım 4, 3 resimden 2. Samsung Galaxy Tab 2 7.0 Camera Replacement: adım 4, 3 resimden 3.
    • Locate the 8 flex cables attached to the motherboard.
    • Using a nylon spudger, gently detach each flex cable from the motherboard.
    • Be careful when detaching flex cables. Excessive force and sharp objects have the potential to damage these components.
    • Lift the motherboard from the device and set it aside.
  5. Samsung Galaxy Tab 2 7.0 Camera Replacement: adım 5, 1 resimden 1.
    • Locate the camera towards the top of the device.
    • Use a nylon spudger to gently lift the camera and remove it from the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Katija Tarailo
460 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S3-G1, Harley Spring 2017 IUPUI, Team S3-G1, Harley Spring 2017 üyesi
IUPUI-HARLEY-S17S3G1
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 672
