Ana içeriğe geç
Samsung Galaxy Tab 2 7.0 Speaker Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Tab 2 7.0 Speaker Replacement, Speaker: adım 1, 1 resimden 1.
    • Using a nylon spudger or flat plastic opening tool, pry open the back of the device.
    • It is easy to begin this process by starting at the micro SD card insert, as shown in the pictures.
  2. Samsung Galaxy Tab 2 7.0 Speaker Replacement: adım 2, 2 resimden 1. Samsung Galaxy Tab 2 7.0 Speaker Replacement: adım 2, 2 resimden 2.
    • Using a phillips head screwdriver, remove the two 4mm screws holding down each speaker.
  3. Samsung Galaxy Tab 2 7.0 Speaker Replacement: adım 3, 3 resimden 1. Samsung Galaxy Tab 2 7.0 Speaker Replacement: adım 3, 3 resimden 2. Samsung Galaxy Tab 2 7.0 Speaker Replacement: adım 3, 3 resimden 3.
    • Locate the flex cable attaching each speaker to the motherboard.
    • Carefully use a nylon spudger to lift the cable and detach it from the motherboard.
    • Lift the speaker out of the device.
    • If the speaker does not come out easily, use a flat tool under the flex cable to slightly lift the speaker out of place before removing it with your hands.
    • Be careful when working with flex cables. Excessive force and sharp tools have the potential to damage these components.
Sonuç
Katija Tarailo
460 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S3-G1, Harley Spring 2017 IUPUI, Team S3-G1, Harley Spring 2017 üyesi
IUPUI-HARLEY-S17S3G1
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 9
Her zaman: 735
