Ana içeriğe geç
Samsung Galaxy Tab 3 10.1 Front-Facing Camera Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Tab 3 10.1 Front-Facing Camera Replacement, Rear Case: adım 1, 2 resimden 1. Samsung Galaxy Tab 3 10.1 Front-Facing Camera Replacement, Rear Case: adım 1, 2 resimden 2.
    • Insert an opening pick between the rear case and the plastic rim.
    • You may need to add multiple picks to detach the clips.
    • Slide the pick along the edge of the rear case until you release the plastic clips attaching the rear case to the display.
    • Continue to slide the pick around the edge of the rear case until all clips are released.
  2. Samsung Galaxy Tab 3 10.1 Front-Facing Camera Replacement: adım 2, 2 resimden 1. Samsung Galaxy Tab 3 10.1 Front-Facing Camera Replacement: adım 2, 2 resimden 2.
    • Lift the case up to remove it.
  3. Samsung Galaxy Tab 3 10.1 Front-Facing Camera Replacement, Front-Facing Camera: adım 3, 1 resimden 1.
    • Lift the plastic frame to remove.
    • Avoid the three delicate ribbon cables.
  4. Samsung Galaxy Tab 3 10.1 Front-Facing Camera Replacement: adım 4, 3 resimden 1. Samsung Galaxy Tab 3 10.1 Front-Facing Camera Replacement: adım 4, 3 resimden 2. Samsung Galaxy Tab 3 10.1 Front-Facing Camera Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Use the flat end of a plastic spudger to pry up the press-fit connector from the motherboard.
    • Remove the camera by gently pulling upward with a pair of tweezers.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Corey Brown
8.826 İtibar
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 876
