Ana içeriğe geç
Samsung Galaxy Tab 3 7.0 3G Back Cover and Frame Replacement
Görüntüleme: 113 B
İstatistikleri görüntüle:
Son 24 Saat:
3
Son 7 Gün:
24
Son 30 Gün:
107
Her zaman:
113.031
Yorumlar: 8
1 comment on steps, 7 guide comments.
Go to guide comments
Tamamlandı: 22
22 kişi bu kılavuzu "tamamlandı" olarak işaretledi. Sıradaki sen olacak mısın?
Sık Kullanılanlar: 7
7 kişi bu kılavuzu favorilerine ekledi (ve abone oldu). Sıradaki sen olacak mısın?
Gerekli Süre: 5 dakika
Zorluk: Kolay
This disassembling guide is useful for many repair guides involving the device such as battery replacement, camera replacement etc..
Neye ihtiyacın var
Aletler
    1. Samsung Galaxy Tab 3 7.0 3G Back Cover and Frame Replacement, White Backing: adım 1, 3 resimden 1. Samsung Galaxy Tab 3 7.0 3G Back Cover and Frame Replacement, White Backing: adım 1, 3 resimden 2. Samsung Galaxy Tab 3 7.0 3G Back Cover and Frame Replacement, White Backing: adım 1, 3 resimden 3.
      • To begin working on your repair, turn your device over and open the micro SD slot, as shown in the first picture.
      • Using the flat part of the spudger, begin pushing it between the white backing and the SD slot. Continue to pry off the white backing until you hear several clicks and see the white backing lift up, as shown in the second picture.
      • Continue to pry off the white backing around the device, as shown in the third picture.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Galaxy Tab 3 7.0 3G Back Cover and Frame Replacement: adım 2, 1 resimden 1.
      • Once the backing has been pried off all around the device, remove the white backing.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Galaxy Tab 3 7.0 3G Back Cover and Frame Replacement, Silver Siding: adım 3, 3 resimden 1. Samsung Galaxy Tab 3 7.0 3G Back Cover and Frame Replacement, Silver Siding: adım 3, 3 resimden 2. Samsung Galaxy Tab 3 7.0 3G Back Cover and Frame Replacement, Silver Siding: adım 3, 3 resimden 3.
      • To remove the silver siding, begin by pushing the spudger between the frame and the screen, as shown in the first picture.
      • Do this until you see the silver siding begin to lift up. Continue doing this around the edges of the device, as shown in the second picture.
      • Once you silver siding is loose all around the device, remove it carefully with your hand as shown in the third picture.
      FixBot'a Sor
      Yorum Ekle
Sonuç
22 farklı kişi bu kılavuzu tamamladı.
Andrea Flores
1.534 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-30, Maness Fall 2014 Cal Poly, Team 14-30, Maness Fall 2014 üyesi
CPSU-MANESS-F14S14G30
4 Üyeler
72 adet Kılavuz yazıldı
7Kılavuz Yorumları
i need the back panel
Nithyanand 333 - Yanıt Paylaş
Awesome, I was able to use this guide to easily replace the integrated battery in my seven inch version of the Galaxy Tab 3!
segin2005 - Yanıt Paylaş
Hello,
I cannot understand why my tablet galaxy T211 3 7.0 3G can't turn on anymore... The screen is black, i don't know is happening and all the "internet tricks" power off- sounds etc doesn't function do you have any solution?
Thank u
alizeescolas - Yanıt Paylaş
It would be easy the said. It will only take five minutes they said. Yeah right you lying ass ##&&%. It took me 2 and a half hours to get off and it was NOT easy. Not to mention the tools I was using to get it off chipped and cracked part of the white back cover.
Queen Valencia - Yanıt Paylaş
Never buying a Galaxy Tab again!
RoRoTX Wills - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 24
Son 30 gün: 107
Her zaman: 113,031
