Ana içeriğe geç
Samsung Galaxy Tab 3 7.0 Motherboard Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Samsung Galaxy Tab 3 7.0 Motherboard Replacement, Battery: adım 1, 2 resimden 1. Samsung Galaxy Tab 3 7.0 Motherboard Replacement, Battery: adım 1, 2 resimden 2.
    • With a plastic opening tool, gently insert the prying end in between the glass digitizer and the silver frame from the front of the device.
  2. Samsung Galaxy Tab 3 7.0 Motherboard Replacement: adım 2, 3 resimden 1. Samsung Galaxy Tab 3 7.0 Motherboard Replacement: adım 2, 3 resimden 2. Samsung Galaxy Tab 3 7.0 Motherboard Replacement: adım 2, 3 resimden 3.
    • Working slowly and carefully, move around the entirety of the face of the device. Small plastic clips should release, if not, apply gentle outwards pressure until you hear the clips popping off.
  3. Samsung Galaxy Tab 3 7.0 Motherboard Replacement: adım 3, 3 resimden 1. Samsung Galaxy Tab 3 7.0 Motherboard Replacement: adım 3, 3 resimden 2. Samsung Galaxy Tab 3 7.0 Motherboard Replacement: adım 3, 3 resimden 3.
    • To begin actual removal of the battery itself, remove the four designated screws with your screwdriver.
    • Once the screws are removed, use either the tip of your screwdriver or a pair of tweezers to pull up the battery connector. Pull directly up and the connector should pop out.
    • Once the battery is removed, it should look as it does in the third picture.
  4. Samsung Galaxy Tab 3 7.0 Motherboard Replacement: adım 4, 1 resimden 1.
    • To finish battery replacement, place your new battery where the old battery was in your device, as shown in the picture.
  5. Samsung Galaxy Tab 3 7.0 Motherboard Replacement, Motherboard: adım 5, 3 resimden 1. Samsung Galaxy Tab 3 7.0 Motherboard Replacement, Motherboard: adım 5, 3 resimden 2. Samsung Galaxy Tab 3 7.0 Motherboard Replacement, Motherboard: adım 5, 3 resimden 3.
    • Begin replacement of the motherboard by releasing all connections holding down the motherboard, shown in the first picture.
    • To do this, use your spudger, tweezers, or a plastic opening tool and gently lift the connections up from their ports.
    • Once you separate all connections, the back of your device should look as it does in the third picture.
  6. Samsung Galaxy Tab 3 7.0 Motherboard Replacement: adım 6, 3 resimden 1. Samsung Galaxy Tab 3 7.0 Motherboard Replacement: adım 6, 3 resimden 2. Samsung Galaxy Tab 3 7.0 Motherboard Replacement: adım 6, 3 resimden 3.
    • Once all connections have been released, begin removing the screws shown in the first two pictures.
    • Once all screws have been removed, the motherboard can now be removed and replaced with a new one.
Sonuç
48 farklı kişi bu kılavuzu tamamladı.
Brandon Dimaya
2.866 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-20, Regan Spring 2014 Cal Poly, Team 7-20, Regan Spring 2014 üyesi
CPSU-REGAN-S14S7G20
4 Üyeler
10 adet Kılavuz yazıldı
8 Yorum
So I will add to this, please do not take the back case off as shown here, it will cause damage to the case and will not snap back in place properly. The casing comes off around the digitizer itself, if you decide to do this yourself slide your spudger or plastic pick along the sides of the screen, applying enough pressure to snap the casing from the screens frame. I work on Samsung tablets for a living and know doing it the way they show will cause damage to the casing. Basically what is shown in step 2 of removing the silver frame is what you should do first, not in separate steps. If you don't have any warranty then by all means do it how you want, if you have warranty dont do this as it can void your warranty.
Travis - Yanıt
Even if's it's not a screen replacement instruction it really help me start on the replacement. Thanks for the help
Stephane Venne - Yanıt
Hi, do other models of the Samsung tablets fit the sm-210r?
If so which ones?
sergek2 - Yanıt
Where can I get a motherboard for a T-211?++My email is gemartin46@gmail.com
Thanks
George Earl Martin - Yanıt
Am i able to just replace the hard drive or remove it and put it on a different motherboard? My device wont charge or turn on despite having a fully charged battery.....
mike - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 27
Her zaman: 39,477
