Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
  1. Start out by separating the screen from the back cover using the larger plastic opening tool to pry them apart. Be careful when removing the screen as negligence can cause damage.
    • Start out by separating the screen from the back cover using the larger plastic opening tool to pry them apart.
    • Be careful when removing the screen as negligence can cause damage.
  2. Once every part of the screen is separated from the back cover, you should be able to fully remove it with your hands. Once every part of the screen is separated from the back cover, you should be able to fully remove it with your hands.
    • Once every part of the screen is separated from the back cover, you should be able to fully remove it with your hands.
  3. Nintendo Switch Setleri
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. To remove the battery you must use something small, such as tweezers, to disconnect the battery from its port. Note: the connection lifts up to remove.
    • To remove the battery you must use something small, such as tweezers, to disconnect the battery from its port.
    • Note: the connection lifts up to remove.
  5. After the battery is disconnected, use the pulling tab to safely remove the battery.
    • After the battery is disconnected, use the pulling tab to safely remove the battery.
  6. Disconnect Audio Jack from Motherboard.
    • Disconnect Audio Jack from Motherboard.
  7. Unscrew the 2.9mm phillips #000 screws from the audio jack and remove component from the tablet. Unscrew the 2.9mm phillips #000 screws from the audio jack and remove component from the tablet. Unscrew the 2.9mm phillips #000 screws from the audio jack and remove component from the tablet.
    • Unscrew the 2.9mm phillips #000 screws from the audio jack and remove component from the tablet.
Sonuç
Bir başkası bu kılavuzu tamamladı.
anthony gonzalez
282 İtibar
3 adet Kılavuz yazıldı
Takım
USF Tampa, Team 4-2, Brown Fall 2014 USF Tampa, Team 4-2, Brown Fall 2014 üyesi
USFT-BROWN-F14S4G2
3 Üyeler
26 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 1,592
