Ana içeriğe geç
Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Display Assembly - Touch screen & LCD Display: adım 1, 3 resimden 1. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Display Assembly - Touch screen & LCD Display: adım 1, 3 resimden 2. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Display Assembly - Touch screen & LCD Display: adım 1, 3 resimden 3.
    • Put the scotch tape in order not to scatter pieces of glass.
    • Remove any memory card and SIM card (if the tablet is 3G version).
  2. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Battery / Back Cover: adım 2, 3 resimden 1. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Battery / Back Cover: adım 2, 3 resimden 2. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Battery / Back Cover: adım 2, 3 resimden 3.
    • Using plastic tools remove the back / battery cover.
    • Be careful with the Power and Volume buttons.
  3. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: adım 3, 1 resimden 1.
    • Before doing anything, disconnect the battery.
  4. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Micro USB Charging Port / Dock with Flex Cable: adım 4, 3 resimden 1. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Micro USB Charging Port / Dock with Flex Cable: adım 4, 3 resimden 2. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Micro USB Charging Port / Dock with Flex Cable: adım 4, 3 resimden 3.
    • This step is only if you want to replace the micro USB port flex cable.
    • Remove the two screws and disconnect the charging port flex cable from the main board.
    • Use a plastic tool to unstick the flex cable from the middle frame.
  5. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Battery: adım 5, 3 resimden 1. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Battery: adım 5, 3 resimden 2. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Battery: adım 5, 3 resimden 3.
    • This step is for only if you want to change the battery.
    • The battery is stuck to the middle panel.
    • Use the white sticker to remove it.
  6. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Components 1: adım 6, 3 resimden 1. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Components 1: adım 6, 3 resimden 2. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Components 1: adım 6, 3 resimden 3.
    • 2x loudspeackers
    • Power & Volume buttons flex cable
    • Audio jack flex cable
  7. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Components 2: adım 7, 2 resimden 1. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Components 2: adım 7, 2 resimden 2.
    • Front camera
    • Wi-Fi antenna
  8. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: adım 8, 3 resimden 1. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: adım 8, 3 resimden 2. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: adım 8, 3 resimden 3.
    • Use a heat gun or hair dryer and warm the touch screen glass. This will make the adhesive more flexible and the separation easier.
    • Use a gloves to avoid any injurys from glass.
    • Do not rush.
  9. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: adım 9, 3 resimden 1. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: adım 9, 3 resimden 2. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: adım 9, 3 resimden 3.
    • Beware for the menu buttons flex cable.
  10. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: adım 10, 2 resimden 1. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: adım 10, 2 resimden 2.
    • Always test the new spare part before final installation.
  11. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: adım 11, 3 resimden 1. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: adım 11, 3 resimden 2. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: adım 11, 3 resimden 3.
    • Transfer the black tape from the old display. It keeps the distance the display from the battery and protects it from overheat.
    • If the adhesive tape is not in good condition you must install a new one.
  12. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: adım 12, 2 resimden 1. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: adım 12, 2 resimden 2.
    • Start with reassembling.
    • Did you do it successfully.
Sonuç
18 farklı kişi bu kılavuzu tamamladı.
ZFix
191.882 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
321 Üyeler
1.516 adet Kılavuz yazıldı
Bir Yorum
Awesome guide, was so easy to replace complete LCD digitiser and glass all in one unit.
capinneemo - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 10
Son 30 gün: 51
Her zaman: 25,276
