Giriş
If your tablet has a broken touch screen glass (digitizer), LCD display or you want to chang the micro USB charging port, loudspeakers, audio jack connector, etc., with this guide we will help you to do it.
Neye ihtiyacın var
Videoya Genel Bakış
Put the scotch tape in order not to scatter pieces of glass.
Remove any memory card and SIM card (if the tablet is 3G version).
Remove the two screws and disconnect the charging port flex cable from the main board.
Use a plastic tool to unstick the flex cable from the middle frame.
The battery is stuck to the middle panel.
Use the white sticker to remove it.
2x loudspeackers
Power & Volume buttons flex cable
Audio jack flex cable
18 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Awesome guide, was so easy to replace complete LCD digitiser and glass all in one unit.
