Ana içeriğe geç
Samsung Galaxy Tab 3 8.0 Front Camera Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Tab 3 8.0 Front Camera Replacement, Battery - Open up the tablet: adım 1, 2 resimden 1. Samsung Galaxy Tab 3 8.0 Front Camera Replacement, Battery - Open up the tablet: adım 1, 2 resimden 2.
    • Start out by separating the screen from the back cover using the larger plastic opening tool to pry them apart.
    • Be careful when removing the screen as negligence can cause damage.
  2. Samsung Galaxy Tab 3 8.0 Front Camera Replacement, Remove Back Cover: adım 2, 2 resimden 1. Samsung Galaxy Tab 3 8.0 Front Camera Replacement, Remove Back Cover: adım 2, 2 resimden 2.
    • Once every part of the screen is separated from the back cover, you should be able to fully remove it with your hands.
  3. Samsung Galaxy Tab 3 8.0 Front Camera Replacement, Disconnect Battery: adım 3, 2 resimden 1. Samsung Galaxy Tab 3 8.0 Front Camera Replacement, Disconnect Battery: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • To remove the battery you must use something small, such as tweezers, to disconnect the battery from its port.
    • Note: the connection lifts up to remove.
  4. Samsung Galaxy Tab 3 8.0 Front Camera Replacement, Remove Battery: adım 4, 1 resimden 1.
    • After the battery is disconnected, use the pulling tab to safely remove the battery.
  5. Samsung Galaxy Tab 3 8.0 Front Camera Replacement, Remove the Front Camera: adım 5, 3 resimden 1. Samsung Galaxy Tab 3 8.0 Front Camera Replacement, Remove the Front Camera: adım 5, 3 resimden 2. Samsung Galaxy Tab 3 8.0 Front Camera Replacement, Remove the Front Camera: adım 5, 3 resimden 3.
    • Take the plastic remover tool and gently lift the component free from the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
anthony gonzalez
313 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-2, Brown Fall 2014 USF Tampa, Team 4-2, Brown Fall 2014 üyesi
USFT-BROWN-F14S4G2
3 Üyeler
26 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 15
Her zaman: 698
