Ana içeriğe geç
Samsung Galaxy Tab 3 8.0 Proximity Sensor Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Tab 3 8.0 Proximity Sensor Replacement, Battery - Open up the tablet: adım 1, 2 resimden 1. Samsung Galaxy Tab 3 8.0 Proximity Sensor Replacement, Battery - Open up the tablet: adım 1, 2 resimden 2.
    • Start out by separating the screen from the back cover using the larger plastic opening tool to pry them apart.
    • Be careful when removing the screen as negligence can cause damage.
  2. Samsung Galaxy Tab 3 8.0 Proximity Sensor Replacement, Remove Back Cover: adım 2, 2 resimden 1. Samsung Galaxy Tab 3 8.0 Proximity Sensor Replacement, Remove Back Cover: adım 2, 2 resimden 2.
    • Once every part of the screen is separated from the back cover, you should be able to fully remove it with your hands.
  3. Samsung Galaxy Tab 3 8.0 Proximity Sensor Replacement, Disconnect Battery: adım 3, 2 resimden 1. Samsung Galaxy Tab 3 8.0 Proximity Sensor Replacement, Disconnect Battery: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    • To remove the battery you must use something small, such as tweezers, to disconnect the battery from its port.
    • Note: the connection lifts up to remove.
  4. Samsung Galaxy Tab 3 8.0 Proximity Sensor Replacement, Remove Battery: adım 4, 1 resimden 1.
    • After the battery is disconnected, use the pulling tab to safely remove the battery.
  5. Samsung Galaxy Tab 3 8.0 Proximity Sensor Replacement, Disconnect from Motherboard: adım 5, 1 resimden 1.
    • With a plastic remover tool, gently unseat the connection of the proximity sensor to the motherboard.
  6. Samsung Galaxy Tab 3 8.0 Proximity Sensor Replacement, Remove Proximity Sensor: adım 6, 3 resimden 1. Samsung Galaxy Tab 3 8.0 Proximity Sensor Replacement, Remove Proximity Sensor: adım 6, 3 resimden 2. Samsung Galaxy Tab 3 8.0 Proximity Sensor Replacement, Remove Proximity Sensor: adım 6, 3 resimden 3.
    • Gently wedge the plastic remover tool and pry antenna loose, and lift it from the proximity sensor. The Sensor can then simply lifted from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Peter Paoletta
2.109 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-2, Brown Fall 2014 USF Tampa, Team 4-2, Brown Fall 2014 üyesi
USFT-BROWN-F14S4G2
3 Üyeler
26 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 11
Her zaman: 2,309
