Giriş
This step by step troubleshooting guide can be used to resolve issues such as water damage, heat and/or excessive heat that may arise with the Samsung Galaxy Tab 3 8.0 Speakers.
Great caution must be taken when removing or replacing parts of the tablet as further damage can occur.
Neye ihtiyacın var
Start out by separating the screen from the back cover using the larger plastic opening tool to pry them apart.
Once every part of the screen is separated from the back cover, you should be able to fully remove it with your hands.
After the battery is disconnected, use the pulling tab to safely remove the battery.
Unscrew the 2.9mm screws from the speakers using a Phillips head #000 screwdriver, then lift the speakers from the device.
4 farklı kişi bu kılavuzu tamamladı.
