Ana içeriğe geç
Samsung Galaxy Tab 3 Kids Speaker Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Tab 3 Kids Speaker Replacement, Speaker: adım 1, 2 resimden 1. Samsung Galaxy Tab 3 Kids Speaker Replacement, Speaker: adım 1, 2 resimden 2.
    • Using the plastic opening tool to open up the device, wedge in the seam between the screen and the back cover. Slide the tool around all the edges and remove the screen from the back cover
  2. Samsung Galaxy Tab 3 Kids Speaker Replacement: adım 2, 1 resimden 1.
    • Unplug the battery connection carefully using the plastic opening tool.
  3. Samsung Galaxy Tab 3 Kids Speaker Replacement: adım 3, 3 resimden 1. Samsung Galaxy Tab 3 Kids Speaker Replacement: adım 3, 3 resimden 2. Samsung Galaxy Tab 3 Kids Speaker Replacement: adım 3, 3 resimden 3.
    • Before Changing the motherboard, you have to lift up the (ZIF) zero insertion force by using the plastic opening tool, separating the connector from the batter ribbon cable
  4. Samsung Galaxy Tab 3 Kids Speaker Replacement: adım 4, 2 resimden 1. Samsung Galaxy Tab 3 Kids Speaker Replacement: adım 4, 2 resimden 2.
    • Unscrew the ten 4mm PH000 bolts holding the motherboard on the device
  5. Samsung Galaxy Tab 3 Kids Speaker Replacement: adım 5, 3 resimden 1. Samsung Galaxy Tab 3 Kids Speaker Replacement: adım 5, 3 resimden 2. Samsung Galaxy Tab 3 Kids Speaker Replacement: adım 5, 3 resimden 3.
    • Remove the mother board from the device by carefully lifting it out.
  6. Samsung Galaxy Tab 3 Kids Speaker Replacement: adım 6, 1 resimden 1.
    • Remove the last screw holding down the speaker.
  7. Samsung Galaxy Tab 3 Kids Speaker Replacement: adım 7, 3 resimden 1. Samsung Galaxy Tab 3 Kids Speaker Replacement: adım 7, 3 resimden 2. Samsung Galaxy Tab 3 Kids Speaker Replacement: adım 7, 3 resimden 3.
    • Remove the speaker using the plastic splunger
Sonuç
Bir başkası bu kılavuzu tamamladı.
ajhoffman
182 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-6, Nance Fall 2016 USF Tampa, Team 2-6, Nance Fall 2016 üyesi
USFT-NANCE-F16S2G6
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 181
