Ana içeriğe geç
Samsung Galaxy Tab 3 Lite Motherboard Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Tab 3 Lite Motherboard Replacement, Rear Case: adım 1, 3 resimden 1. Samsung Galaxy Tab 3 Lite Motherboard Replacement, Rear Case: adım 1, 3 resimden 2. Samsung Galaxy Tab 3 Lite Motherboard Replacement, Rear Case: adım 1, 3 resimden 3.
    • Using a plastic opening tool, wedge in the seam between the screen and the case.
    • Rock the tool by moving it towards and away from the middle of the screen, trying to separate the tape holding the screen and case together.
    • This is a long process, so don't try and rush it. Also, be careful about applying pressure.
  2. Samsung Galaxy Tab 3 Lite Motherboard Replacement: adım 2, 3 resimden 1. Samsung Galaxy Tab 3 Lite Motherboard Replacement: adım 2, 3 resimden 2. Samsung Galaxy Tab 3 Lite Motherboard Replacement: adım 2, 3 resimden 3.
    • After separating the tape holding the screen and case together, slowly start taking the screen off the case from the opposite side of the side with the buttons
  3. Samsung Galaxy Tab 3 Lite Motherboard Replacement, Motherboard: adım 3, 3 resimden 1. Samsung Galaxy Tab 3 Lite Motherboard Replacement, Motherboard: adım 3, 3 resimden 2. Samsung Galaxy Tab 3 Lite Motherboard Replacement, Motherboard: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Use a plastic opening tool to lift up the zero insertion force (ZIF) connector holding down the ribbon cable.
    • Use the precision tweezers to gently pull the ribbon cable out of the ZIF connector.
  4. Samsung Galaxy Tab 3 Lite Motherboard Replacement: adım 4, 2 resimden 1. Samsung Galaxy Tab 3 Lite Motherboard Replacement: adım 4, 2 resimden 2.
    • Use the plastic opening tool to lift up the zero insertion force (ZIF) connector holding down the battery ribbon cable.
    • Use the precision tweezers to remove the ribbon cable from the ZIF connector.
  5. Samsung Galaxy Tab 3 Lite Motherboard Replacement: adım 5, 2 resimden 1. Samsung Galaxy Tab 3 Lite Motherboard Replacement: adım 5, 2 resimden 2.
  6. Samsung Galaxy Tab 3 Lite Motherboard Replacement: adım 6, 1 resimden 1.
    • Remove the seven 4mm Phillips J000 screws holding the motherboard in place.
  7. Samsung Galaxy Tab 3 Lite Motherboard Replacement: adım 7, 1 resimden 1.
    • Use the plastic opening tool and gently pry up the tab holding the motherboard in place.
  8. Samsung Galaxy Tab 3 Lite Motherboard Replacement: adım 8, 3 resimden 1. Samsung Galaxy Tab 3 Lite Motherboard Replacement: adım 8, 3 resimden 2. Samsung Galaxy Tab 3 Lite Motherboard Replacement: adım 8, 3 resimden 3.
    • Use the precision tweezers to remove the black plastic corner on top of the motherboard.
    • Use the plastic opening tool to pull the motherboard off the case.
Sonuç
21 farklı kişi bu kılavuzu tamamladı.
Patricia Laird
924 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 11-1, Cheng Spring 2016 USF Tampa, Team 11-1, Cheng Spring 2016 üyesi
USFT-CHENG-S16S11G1
4 Üyeler
12 adet Kılavuz yazıldı
3 Yorum
Thank you friend!
nandoquoos2 - Yanıt
Nice guide, Done very well.
Keith Mullins - Yanıt
Ótimo guia. Esses tutoriais facilitam demais nossa vida. Sou fã! Parabéns
Amaury Souza - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 33
Her zaman: 7,719
