Ana içeriğe geç
Samsung Galaxy Tab 3 Lite Rear Case Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Tab 3 Lite Rear Case Replacement, Rear Case: adım 1, 3 resimden 1. Samsung Galaxy Tab 3 Lite Rear Case Replacement, Rear Case: adım 1, 3 resimden 2. Samsung Galaxy Tab 3 Lite Rear Case Replacement, Rear Case: adım 1, 3 resimden 3.
    • Using a plastic opening tool, wedge in the seam between the screen and the case.
    • Rock the tool by moving it towards and away from the middle of the screen, trying to separate the tape holding the screen and case together.
    • This is a long process, so don't try and rush it. Also, be careful about applying pressure.
  2. Samsung Galaxy Tab 3 Lite Rear Case Replacement: adım 2, 3 resimden 1. Samsung Galaxy Tab 3 Lite Rear Case Replacement: adım 2, 3 resimden 2. Samsung Galaxy Tab 3 Lite Rear Case Replacement: adım 2, 3 resimden 3.
    • After separating the tape holding the screen and case together, slowly start taking the screen off the case from the opposite side of the side with the buttons
Sonuç
To reassemble your device, snap the screen into the case.
12 farklı kişi bu kılavuzu tamamladı.
Kevin Hicks
1.575 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 11-1, Cheng Spring 2016 USF Tampa, Team 11-1, Cheng Spring 2016 üyesi
USFT-CHENG-S16S11G1
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 21
Her zaman: 3,810
