Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Insert the wedge of the nylon spudger and slide it between the front and back panels until the back comes off.
Peel off the green tape that covers the connectors for the three black strips.
Use the tip of a spudger or your fingernail to flip up the small retaining flaps.
Use a Phillips #00 screwdriver to remove the four 3.2mm screws.
Detach the red, blue, and black cables by prying up on the white connector from the motherboard.
If using fingers instead, pull evenly on the full width of the cable so the wires are not overly strained.
Use the nylon spudger to remove the battery by prying up on the edges.
52 farklı kişi bu kılavuzu tamamladı.
5 Yorum
Well, I know what I did wrong. I thought I was super careful, but I damaged the black connector. (Please pay extra attention to the red warning area in Gunzl’s instructions.) It separates from the board extremely easy. My husband was worried about my taking on this task. I know what I did wrong, but that doesn’t help the fact that I will be purchasing another tablet for him. I’m not sure I will purchase another Samsung, but perhaps all the tablets has such fragile inner workings.
Don’t worry, you’re not the only one! :(
Regarding Step 4, Take note of the red warning comment! Very easy to pull up the connector off the board!!!
Unfortunately I just that because I didn’t hold down the connectors with tweezers (or something) and then botched an attempted reflow of the solder, costing even more time and money! :(
