Ana içeriğe geç
Samsung Galaxy Tab 4 10.1 Front and Rear Camera Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Tab 4 10.1 Front and Rear Camera Replacement, Battery: adım 1, 2 resimden 1. Samsung Galaxy Tab 4 10.1 Front and Rear Camera Replacement, Battery: adım 1, 2 resimden 2.
    • Insert the wedge of the nylon spudger and slide it between the front and back panels until the back comes off.
  2. Samsung Galaxy Tab 4 10.1 Front and Rear Camera Replacement: adım 2, 1 resimden 1.
    • Peel off the green tape that covers the connectors for the three black strips.
    • Use the tip of a spudger or your fingernail to flip up the small retaining flaps.
  3. Samsung Galaxy Tab 4 10.1 Front and Rear Camera Replacement: adım 3, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the four 3.2mm screws.
  4. Samsung Galaxy Tab 4 10.1 Front and Rear Camera Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Detach the red, blue, and black cables by prying up on the white connector from the motherboard.
    • If using fingers instead, pull evenly on the full width of the cable so the wires are not overly strained.
    • If you pull too hard you can damage the connector on the circuit board. Use a spudger or tweezers to push down on the black connector on the board while gently prying the battery connector loose. The connector breaks VERY easily.
  5. Samsung Galaxy Tab 4 10.1 Front and Rear Camera Replacement: adım 5, 1 resimden 1.
    • Use the nylon spudger to remove the battery by prying up on the edges.
  6. Samsung Galaxy Tab 4 10.1 Front and Rear Camera Replacement: adım 6, 1 resimden 1.
    • Once the battery is loose, lift it out of the device.
  7. Samsung Galaxy Tab 4 10.1 Front and Rear Camera Replacement, Motherboard: adım 7, 2 resimden 1. Samsung Galaxy Tab 4 10.1 Front and Rear Camera Replacement, Motherboard: adım 7, 2 resimden 2.
    • Remove the two 2.7mm Phillips #00 screws from the motherboard.
  8. Samsung Galaxy Tab 4 10.1 Front and Rear Camera Replacement: adım 8, 2 resimden 1. Samsung Galaxy Tab 4 10.1 Front and Rear Camera Replacement: adım 8, 2 resimden 2.
    • Use the flat end of a spudger to pry up and disconnect the five press-fit connectors from the motherboard.
  9. Samsung Galaxy Tab 4 10.1 Front and Rear Camera Replacement: adım 9, 2 resimden 1. Samsung Galaxy Tab 4 10.1 Front and Rear Camera Replacement: adım 9, 2 resimden 2.
    • Use a spudger to pry up the motherboard, and remove it from the device.
  10. Samsung Galaxy Tab 4 10.1 Front and Rear Camera Replacement, Front and Rear Camera: adım 10, 2 resimden 1. Samsung Galaxy Tab 4 10.1 Front and Rear Camera Replacement, Front and Rear Camera: adım 10, 2 resimden 2.
    Satın Al
    • Pull up on the cameras with a pair of tweezers to remove.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Blake Klein
70.919 İtibar
50 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 553
