Ana içeriğe geç
Samsung Galaxy Tab 4 7.0 Back Panel Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Samsung Galaxy Tab 4 7.0 Back Panel Replacement, Back Panel: adım 1, 2 resimden 1. Samsung Galaxy Tab 4 7.0 Back Panel Replacement, Back Panel: adım 1, 2 resimden 2.
    • Starting at any corner, insert the pry tool between the chrome screen frame and black phone housing.
    • Slide the pry tool around the tablet while applying force to pry the screen away from the phone housing.
  2. Samsung Galaxy Tab 4 7.0 Back Panel Replacement: adım 2, 1 resimden 1.
    • Carefully separate the rear housing from the front panel assembly.
Bitiş Çizgisi
15 farklı kişi bu kılavuzu tamamladı.
Briana Honeycutt
432 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-3, Remmell Fall 2015 USF Tampa, Team 1-3, Remmell Fall 2015 üyesi
USFT-REMMELL-F15S1G3
4 Üyeler
12 adet Kılavuz yazıldı
3 Yorum
Where are the locking clips? What direction do they face? Is it better to pry in one direction ? Why don't you mention how hard it is to release the back from the front? Why don't you mention that the power won't stay off because it is nearly impossible to handle the device without touching the power button? After a half hour, ruining two new pry bars and numerous gouges in my hands, I achieved one corner loose which would not propagate beyond that point.
Joyce Ronquillo - Yanıt
I know this is 2 years late, but if someone else sees this then I hope it helps them.
When releasing the clips that hold the plastic back on you want to pry away from the screen and then kind of away from the device. It takes much less effort than you think if you are prying down and away.
Like I said I hope this helps. The rest of the guide is spot on. Have a metal spudger for the adhesive that is keeping the battery stuck to the device.
Dane Daughtrey -
This was hard, I had to use a knife first to create a wedge (being careful not to put my hands in the direction were I was exercising force to prevent injuring myself). Then the tool helped but I must say it was destroyed in the process. I also need to say that it was not an iFixit tool so it may be of a different quality than those sold on this website.
aleoje - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 42
Her zaman: 22,344
