Ana içeriğe geç
Samsung Galaxy Tab 4 7.0 Camera Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Tab 4 7.0 Camera Replacement, Back Panel: adım 1, 2 resimden 1. Samsung Galaxy Tab 4 7.0 Camera Replacement, Back Panel: adım 1, 2 resimden 2.
    • Starting at any corner, insert the pry tool between the chrome screen frame and black phone housing.
    • Slide the pry tool around the tablet while applying force to pry the screen away from the phone housing.
  2. Samsung Galaxy Tab 4 7.0 Camera Replacement: adım 2, 1 resimden 1.
    • Carefully separate the rear housing from the front panel assembly.
  3. Samsung Galaxy Tab 4 7.0 Camera Replacement, Motherboard: adım 3, 3 resimden 1. Samsung Galaxy Tab 4 7.0 Camera Replacement, Motherboard: adım 3, 3 resimden 2. Samsung Galaxy Tab 4 7.0 Camera Replacement, Motherboard: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Using the bent tweezers, carefully pull the flat cables away from the connectors.
    • Do not bend the flat cables at the tips as they may become permanently deformed.
  4. Samsung Galaxy Tab 4 7.0 Camera Replacement: adım 4, 3 resimden 1. Samsung Galaxy Tab 4 7.0 Camera Replacement: adım 4, 3 resimden 2. Samsung Galaxy Tab 4 7.0 Camera Replacement: adım 4, 3 resimden 3.
    • Using the plastic opening tool, gently pry the chip connections away from the motherboard.
  5. Samsung Galaxy Tab 4 7.0 Camera Replacement: adım 5, 2 resimden 1. Samsung Galaxy Tab 4 7.0 Camera Replacement: adım 5, 2 resimden 2.
    • Use the Phillips 000 screwdriver to remove the remaining five 1.2 mm screws.
  6. Samsung Galaxy Tab 4 7.0 Camera Replacement: adım 6, 2 resimden 1. Samsung Galaxy Tab 4 7.0 Camera Replacement: adım 6, 2 resimden 2.
    • Use extreme care while removing the motherboard to avoid damaging the component.
    • Remove the motherboard by rotating it away from the rest of the phone as shown in the first photo.
  7. Samsung Galaxy Tab 4 7.0 Camera Replacement, Camera: adım 7, 3 resimden 1. Samsung Galaxy Tab 4 7.0 Camera Replacement, Camera: adım 7, 3 resimden 2. Samsung Galaxy Tab 4 7.0 Camera Replacement, Camera: adım 7, 3 resimden 3.
    Satın Al
    • With the tweezers grab the base of the wire harness and slide it outward in the direction shown.
    • This can be done for either camera on the tablet.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Aubrey Goodwin
2.700 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-3, Remmell Fall 2015 USF Tampa, Team 1-3, Remmell Fall 2015 üyesi
USFT-REMMELL-F15S1G3
4 Üyeler
12 adet Kılavuz yazıldı
3 Yorum
My camera on the Tab 4 is fine, but the len on the back is scratched. Can I get a replacement for the lens? If so where can I purchase this and is it comparable with other Tabs or Cells lens. I am not looking for a camera, Im look for the glass that protects the said camera.
Amanda Ellenberger - Yanıt
पॉप आर्ट मुझे चाहिये
Jagdish Mote - Yanıt
टॅब पार्ट खरेदी करना है मुझको
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 11
Her zaman: 4,301
