Giriş
The front and rear facing cameras are both right next to each other and require the same tools and process for removal.
Neye ihtiyacın var
Starting at any corner, insert the pry tool between the chrome screen frame and black phone housing.
Slide the pry tool around the tablet while applying force to pry the screen away from the phone housing.
Using the bent tweezers, carefully pull the flat cables away from the connectors.
With the tweezers grab the base of the wire harness and slide it outward in the direction shown.
9 farklı kişi bu kılavuzu tamamladı.
3 Yorum
My camera on the Tab 4 is fine, but the len on the back is scratched. Can I get a replacement for the lens? If so where can I purchase this and is it comparable with other Tabs or Cells lens. I am not looking for a camera, Im look for the glass that protects the said camera.
पॉप आर्ट मुझे चाहिये
टॅब पार्ट खरेदी करना है मुझको
