Ana içeriğe geç
Samsung Galaxy Tab 4 7.0 Home Button Replacement
Neye ihtiyacın var
    1. Samsung Galaxy Tab 4 7.0 Home Button Replacement, Home Button: adım 1, 3 resimden 1. Samsung Galaxy Tab 4 7.0 Home Button Replacement, Home Button: adım 1, 3 resimden 2. Samsung Galaxy Tab 4 7.0 Home Button Replacement, Home Button: adım 1, 3 resimden 3.
      • Power off the tablet.
      • Using a plastic opening tool, pry open the back case by inserting the tool into the seam and moving it in the gap between front and back panel of the tablet.
      • Insert triangle opening picks into the gaps as you work to keep the back panel separated.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Galaxy Tab 4 7.0 Home Button Replacement: adım 2, 2 resimden 1. Samsung Galaxy Tab 4 7.0 Home Button Replacement: adım 2, 2 resimden 2.
      • Using the flat end of a spudger, unclip the press fit connections below the battery and at the top near the camera.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Galaxy Tab 4 7.0 Home Button Replacement: adım 3, 2 resimden 1. Samsung Galaxy Tab 4 7.0 Home Button Replacement: adım 3, 2 resimden 2.
      • Use a plastic opening tool to pull up the locking clip of battery ZIF connector.
      • Disconnect the battery by sliding out the golden ribbon cable.
      FixBot'a Sor
      Yorum Ekle
    4. Samsung Galaxy Tab 4 7.0 Home Button Replacement: adım 4, 2 resimden 1. Samsung Galaxy Tab 4 7.0 Home Button Replacement: adım 4, 2 resimden 2.
      • Use a Phillips #00 screwdriver to remove five 1.7 mm screws from the top and bottom edges of the motherboard.
      FixBot'a Sor
      Yorum Ekle
    5. Samsung Galaxy Tab 4 7.0 Home Button Replacement: adım 5, 1 resimden 1.
      • Use a plastic opening tool to carefully lift up the motherboard and remove it.
      • Do not twist the motherboard if it does not lift out. Double check that all of the connections have been disengaged and use another technique to lift it.
      FixBot'a Sor
      Yorum Ekle
    6. Samsung Galaxy Tab 4 7.0 Home Button Replacement: adım 6, 3 resimden 1. Samsung Galaxy Tab 4 7.0 Home Button Replacement: adım 6, 3 resimden 2. Samsung Galaxy Tab 4 7.0 Home Button Replacement: adım 6, 3 resimden 3.
      Bu adımda kullanılan alet:
      Plastic Cards
      $2.99
      • Use a heat gun or hair drier to heat up the edge of the digitizer. This may help to remove it easily. Do not heat it too much.
      • To remove the digitizer, insert and move a plastic opening pick to create a gap between the digitizer and screen.
      • Carefully lift up the digitizer a little bit and insert a plastic opening card to separate the digitizer from the screen.
      • Do not use sharp edge tool, as it may damage your screen.
      • There are two things to be very careful of. The cable from the digitizer through to the motherboard goes through the top section, and could be damaged.
      • The tabs on the side of the home button are light rubber, which gives the return spring to the home key. The rubber seems less resistant to the heat gun than the glue, so if you're not careful you will end up with a pool of melted rubber. In any case, with this method of removing the digitizer, you may not save the existing home button.
      FixBot'a Sor
      Yorum Ekle
    7. Samsung Galaxy Tab 4 7.0 Home Button Replacement: adım 7, 2 resimden 1. Samsung Galaxy Tab 4 7.0 Home Button Replacement: adım 7, 2 resimden 2.
      • Carefully lift up the digitizer. As you do, you will need to slide one of the press fit connectors through the midframe.
      • Be cautious that you do not sever the connector cable.
      FixBot'a Sor
      Yorum Ekle
    8. Samsung Galaxy Tab 4 7.0 Home Button Replacement: adım 8, 1 resimden 1.
      • Carefully remove the old home button and replace with a new one.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Bhavesh Joshi
213 İtibar
1 Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G22, Cardinal Spring 2020 UW Tacoma, Team S1-G22, Cardinal Spring 2020 üyesi
UWT-CARDINAL-S20S1G22
1 Üye
12 adet Kılavuz yazıldı
8Kılavuz Yorumları
Where can we buy the correct home button?
rayramirez - Yanıt Paylaş
I ordered one from Amazon for 8$
dpachota - Yanıt Paylaş
I'm going to have to say that as far as this guide goes, it's fine... but if it was a novel I'd feel let down. "Carefully remove the old home button and replace with a new one." is very much a litote, and "To reassemble your device, follow these instructions in reverse order." is just a let out.
What about the clean up process before re-assembly?
What's the best product to use to clean the glue away from screen and digitizer?
Is it best to clean the glue off completely and actually buy one of the preshaped glue panels?
I have to say, as far as it goes fine, and for a TV series where the hero or heroine walks off into the sunset and you imagine the rest, fine, but for a technical guide some of the crucial details are absent. Or there ought to be a general assembly and cleanup guide on fixit that you can point to. Maybe there is, but I haven't found it.
Caerwyn Pearce - Yanıt Paylaş
@caerwynpearce I love this response.
John Martone - Yanıt Paylaş
and here it is, on the iFixit channel.
https://www.youtube.com/watch?v=VRSokuEk...
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 39
Son 30 gün: 196
Her zaman: 11,159
