Ana içeriğe geç
Samsung Galaxy Tab 4 7.0 Motherboard Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Samsung Galaxy Tab 4 7.0 Motherboard Replacement, Back Panel: adım 1, 2 resimden 1. Samsung Galaxy Tab 4 7.0 Motherboard Replacement, Back Panel: adım 1, 2 resimden 2.
    • Starting at any corner, insert the pry tool between the chrome screen frame and black phone housing.
    • Slide the pry tool around the tablet while applying force to pry the screen away from the phone housing.
  2. Samsung Galaxy Tab 4 7.0 Motherboard Replacement: adım 2, 1 resimden 1.
    • Carefully separate the rear housing from the front panel assembly.
  3. Samsung Galaxy Tab 4 7.0 Motherboard Replacement, Motherboard: adım 3, 3 resimden 1. Samsung Galaxy Tab 4 7.0 Motherboard Replacement, Motherboard: adım 3, 3 resimden 2. Samsung Galaxy Tab 4 7.0 Motherboard Replacement, Motherboard: adım 3, 3 resimden 3.
    • Using the bent tweezers, carefully pull the flat cables away from the connectors.
    • Do not bend the flat cables at the tips as they may become permanently deformed.
  4. Samsung Galaxy Tab 4 7.0 Motherboard Replacement: adım 4, 3 resimden 1. Samsung Galaxy Tab 4 7.0 Motherboard Replacement: adım 4, 3 resimden 2. Samsung Galaxy Tab 4 7.0 Motherboard Replacement: adım 4, 3 resimden 3.
    • Using the plastic opening tool, gently pry the chip connections away from the motherboard.
  5. Samsung Galaxy Tab 4 7.0 Motherboard Replacement: adım 5, 2 resimden 1. Samsung Galaxy Tab 4 7.0 Motherboard Replacement: adım 5, 2 resimden 2.
    • Use the Phillips 000 screwdriver to remove the remaining five 1.2 mm screws.
  6. Samsung Galaxy Tab 4 7.0 Motherboard Replacement: adım 6, 2 resimden 1. Samsung Galaxy Tab 4 7.0 Motherboard Replacement: adım 6, 2 resimden 2.
    • Use extreme care while removing the motherboard to avoid damaging the component.
    • Remove the motherboard by rotating it away from the rest of the phone as shown in the first photo.
    Use caution taking the board out as it does have some tabs that may hold it in place
    Andrew - Yanıt
Sonuç
24 farklı kişi bu kılavuzu tamamladı.
Briana Honeycutt
432 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-3, Remmell Fall 2015 USF Tampa, Team 1-3, Remmell Fall 2015 üyesi
USFT-REMMELL-F15S1G3
4 Üyeler
12 adet Kılavuz yazıldı
4 Yorum
I would like to change my tab 4 motherboard as ic heated so what is the price of new board
Malik - Yanıt
Do the replacement motherboards sold on ifixit come with the operating system installed or do you have to install a new operating system once you replace the motherboard?
Erich Reichard - Yanıt
Good instructions but not complete. My replacement motherboard was delivered without the cameras. I had to remove the cameras from the old motherboard and install them in the new motherboard. Then install the new motherboard.
Richard Kaapuni - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 50
Her zaman: 18,030
