Ana içeriğe geç
Samsung Galaxy Tab 4 7.0 Screen Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Tab 4 7.0 Screen Replacement, Back Panel: adım 1, 2 resimden 1. Samsung Galaxy Tab 4 7.0 Screen Replacement, Back Panel: adım 1, 2 resimden 2.
    • Starting at any corner, insert the pry tool between the chrome screen frame and black phone housing.
    • Slide the pry tool around the tablet while applying force to pry the screen away from the phone housing.
  2. Samsung Galaxy Tab 4 7.0 Screen Replacement: adım 2, 1 resimden 1.
    • Carefully separate the rear housing from the front panel assembly.
  3. Samsung Galaxy Tab 4 7.0 Screen Replacement, Motherboard: adım 3, 3 resimden 1. Samsung Galaxy Tab 4 7.0 Screen Replacement, Motherboard: adım 3, 3 resimden 2. Samsung Galaxy Tab 4 7.0 Screen Replacement, Motherboard: adım 3, 3 resimden 3.
    • Using the bent tweezers, carefully pull the flat cables away from the connectors.
    • Do not bend the flat cables at the tips as they may become permanently deformed.
  4. Samsung Galaxy Tab 4 7.0 Screen Replacement: adım 4, 3 resimden 1. Samsung Galaxy Tab 4 7.0 Screen Replacement: adım 4, 3 resimden 2. Samsung Galaxy Tab 4 7.0 Screen Replacement: adım 4, 3 resimden 3.
    • Using the plastic opening tool, gently pry the chip connections away from the motherboard.
  5. Samsung Galaxy Tab 4 7.0 Screen Replacement: adım 5, 2 resimden 1. Samsung Galaxy Tab 4 7.0 Screen Replacement: adım 5, 2 resimden 2.
    • Use the Phillips 000 screwdriver to remove the remaining five 1.2 mm screws.
  6. Samsung Galaxy Tab 4 7.0 Screen Replacement: adım 6, 2 resimden 1. Samsung Galaxy Tab 4 7.0 Screen Replacement: adım 6, 2 resimden 2.
    • Use extreme care while removing the motherboard to avoid damaging the component.
    • Remove the motherboard by rotating it away from the rest of the phone as shown in the first photo.
    Use caution taking the board out as it does have some tabs that may hold it in place
    Andrew - Yanıt
  7. Samsung Galaxy Tab 4 7.0 Screen Replacement, Battery: adım 7, 3 resimden 1. Samsung Galaxy Tab 4 7.0 Screen Replacement, Battery: adım 7, 3 resimden 2. Samsung Galaxy Tab 4 7.0 Screen Replacement, Battery: adım 7, 3 resimden 3.
    • You do not need to remove the motherboard in order to remove the battery as the photos may indicate.
    • Work the spudger underneath the battery as shown and pry the battery away from the phone case.
    • The battery is attached to the case with adhesive, so a bit of force is required during removal.
  8. Samsung Galaxy Tab 4 7.0 Screen Replacement, Screen: adım 8, 2 resimden 1. Samsung Galaxy Tab 4 7.0 Screen Replacement, Screen: adım 8, 2 resimden 2.
    • Evenly heat the surface of the screen using your heating tool to loosen the adhesive that is holding the screen to the phone case.
    • If using the heating pad, you may have to reheat it once or twice during this process.
    • If you're using a heat gun, avoid heating one spot for more than a few seconds.
  9. Samsung Galaxy Tab 4 7.0 Screen Replacement: adım 9, 3 resimden 1. Samsung Galaxy Tab 4 7.0 Screen Replacement: adım 9, 3 resimden 2. Samsung Galaxy Tab 4 7.0 Screen Replacement: adım 9, 3 resimden 3.
    • Carefully insert the spudger between the glass and the chrome outer frame of the tablet.
    • Now, slowly pry your way around the screen to loosen the glass from the frame.
  10. Samsung Galaxy Tab 4 7.0 Screen Replacement: adım 10, 3 resimden 1. Samsung Galaxy Tab 4 7.0 Screen Replacement: adım 10, 3 resimden 2. Samsung Galaxy Tab 4 7.0 Screen Replacement: adım 10, 3 resimden 3.
    • After you’ve removed the glass from the screen, feed the chip connection through the phone casing.
    • The screen may need a little more force to separate from the upper edge of the tablet.
    This was rather easy. I have been trying to find a place where install/repair guides are accurate and reliable. Thanks iFixIt. Thanks to you, "I FiXED it"!
    fixitbrosmsus - Yanıt
    Can you also include how to replace the LCD screen under the digitizer? Thanks.
    B - Yanıt
    do I have to remove the mother board to replace the digitizer?
    crazychris79 - Yanıt
    I think the only concern by not removing the MoBo would be heating up the components with either a Heat gun or the Heat Pad.
    Lawrence -
Sonuç
36 farklı kişi bu kılavuzu tamamladı.
Aubrey Goodwin
2.700 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-3, Remmell Fall 2015 USF Tampa, Team 1-3, Remmell Fall 2015 üyesi
USFT-REMMELL-F15S1G3
4 Üyeler
12 adet Kılavuz yazıldı
11 Yorum
Where is the microfuse located?
bbruns - Yanıt
Do you have to remove the battery to replace the screen?
Vic Rector - Yanıt
This is digitizer replacement guide - not screen replacement !!
K P - Yanıt
This worked perfectly for me. Thank you!
gjarmour - Yanıt
This worked perfectly for me. I just bought the assembly instead of going through the full deal (which if I had it would have saved me about 30 bucks overall). But was easy enough to do anyway. I still intend to get the digitizer/glass and finish so I have a spare for future breaks. (I have kids and they are hard on these tablets)
gjarmour - Yanıt
After successfully replacing the screen, and reassembling the unit according to the directions, I have a problem with the display image. The unit turns on, but the image does not come on unless I plug un the charger. The image displayed is of the charging batter segmented on 3 different parts of the screen, and lines similar to a schematic. I’ve disassemble the unit, checked the connections, all appear tight, reassembled and the issue is still present.
Any suggestions of what else to look for?
Jim Mason - Yanıt
That may be the Samsung battery (actually a single cell) not connected due to the ribbon contacts not mated correctly. Open the phone and check the ribbon connector. Be sure its tip fits flat inside the slot, and the tiny cover fitted on it.
rayramirez -
This is overly complicated, only steps 1,4,5 and 10-12 are relevant to replacing the digitizer glass.
Also, no mention of removing old adhesive with isopropyl alcohol to ensure a smooth fit for the new digitizer
brendon - Yanıt
As per the previous comment.
Brendon Gould - Yanıt
When reassembling the back cover, be extremely careful to fit the cover sideways over the three micro switches (on the right side when seen from the front). These are the power, volume up, and volume down switches. If you fit the back cover incorrectly, the switches may be blocked and not work, or worse be torn off the motherboard. I am writing this because this is what happened to me! I tore off the power switch and I had to salvage the switch from a different tablet to replace it. And that switch is extremely tiny!!
rayramirez - Yanıt
Screen keeps changing
Lorraine Rego - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 35
Her zaman: 46,174
