Ana içeriğe geç
Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement, Motherboard: adım 1, 2 resimden 1. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement, Motherboard: adım 1, 2 resimden 2.
    • Insert the plastic opening tool into the gap between the device frame and the back panel on any side of the device.
    • Slide the opening tool around the edges of the device to disconnect the back panel from the frame.
  2. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: adım 2, 3 resimden 1. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: adım 2, 3 resimden 2. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: adım 2, 3 resimden 3.
    • Carefully remove the back panel from the frame of the device.
  3. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: adım 3, 3 resimden 1. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: adım 3, 3 resimden 2. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: adım 3, 3 resimden 3.
    • Using a Phillips #00 Screwdriver, remove the five 4 mm screws connecting the motherboard to the frame of the device.
  4. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: adım 4, 3 resimden 1. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: adım 4, 3 resimden 2. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Use the plastic opening tool to unlock the battery wire from the motherboard by flipping-up the small retaining flap.
    • Use the tweezers to carefully remove the battery wire from the motherboard by pulling it away from the retainer flap.
  5. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: adım 5, 3 resimden 1. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: adım 5, 3 resimden 2. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: adım 5, 3 resimden 3.
    • Use the plastic opening tool to unlock the wire on the narrow section of the motherboard by flipping-up the retaining flap.
    • Use the tweezers to carefully remove the wire from the motherboard by sliding it away from the retaining flap.
  6. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: adım 6, 3 resimden 1. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: adım 6, 3 resimden 2. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: adım 6, 3 resimden 3.
    • Disconnect the wire near the bottom of the motherboard by placing the plastic opening tool under the edge of the connector to flip it up.
  7. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: adım 7, 3 resimden 1. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: adım 7, 3 resimden 2. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: adım 7, 3 resimden 3.
    • Disconnect the wire near the top of the motherboard by placing the plastic opening tool under the edge of the connector to flip it up.
  8. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: adım 8, 3 resimden 1. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: adım 8, 3 resimden 2. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: adım 8, 3 resimden 3.
    • Gently remove the motherboard from the frame of the device by grabbing the top and bottom ends and pulling it toward you.
    • Several plastic tabs keep the motherboard in place, so you will have to apply some force.
  9. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement, Rear-Facing Camera: adım 9, 3 resimden 1. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement, Rear-Facing Camera: adım 9, 3 resimden 2. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement, Rear-Facing Camera: adım 9, 3 resimden 3.
    • Flip the motherboard over to view the back side.
    • Locate the rear-facing camera on the motherboard.
  10. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: adım 10, 2 resimden 1. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: adım 10, 2 resimden 2.
    • Use a plastic opening tool to unlock the rear-facing camera wire from the motherboard by flipping up the retaining flap.
  11. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: adım 11, 2 resimden 1. Samsung Galaxy Tab 4 7.0 Sprint Rear-Facing Camera Replacement: adım 11, 2 resimden 2.
    • Use your fingers to grip the camera and carefully pull it out and away from the motherboard
Sonuç
Valentina Franco
434 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-3, Forte Fall 2016 Cal Poly, Team 18-3, Forte Fall 2016 üyesi
CPSU-FORTE-F16S18G3
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 727
