Ana içeriğe geç
Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement, Rear Case: adım 1, 3 resimden 1. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement, Rear Case: adım 1, 3 resimden 2. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement, Rear Case: adım 1, 3 resimden 3.
    • Before disassembling your Samsung Galaxy Tab 4 8.0, be sure it is powered off and you remove the SIM and Micro SD cards.
    • At the top of the tablet, nudge the blue plastic opening tool between the back plastic casing and the front panel's metal rim.
    • Do not use excessive force when prying the clips, fastening the casing together, open because they can easily break.
  2. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: adım 2, 2 resimden 1. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: adım 2, 2 resimden 2.
    • Continue prying the blue plastic opening tool along the perimeter of the tablet to separate the back plastic casing from the front assembly panel.
    • As right-handers, we found it easiest to move clockwise and use more pressure around the corners to facilitate the process.
    • You might hear several popping noises caused by the plastic clips coming undone.
  3. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: adım 3, 2 resimden 1. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: adım 3, 2 resimden 2.
    • To avoid damaging the screen, gently set the tablet with the LCD screen faced down.
    • Firmly grasp the back plastic casing and lift it away from the front assembly panel.
  4. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement, Front Facing Camera: adım 4, 3 resimden 1. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement, Front Facing Camera: adım 4, 3 resimden 2. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement, Front Facing Camera: adım 4, 3 resimden 3.
    • The front camera's ribbon cable is located just above the battery, slightly to the left.
    • Carefully insert the flat end of the blue plastic opening tool under the connector at the end of the ribbon cable.
  5. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: adım 5, 1 resimden 1.
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the front camera’s gold rectangular connector from its socket on the motherboard.
  6. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: adım 6, 2 resimden 1. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Squeeze the gold rectangular piece with the tweezers to gently lift it from its pit.
  7. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement, Rear Facing Camera: adım 7, 2 resimden 1. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement, Rear Facing Camera: adım 7, 2 resimden 2.
    • The back camera will be located near the top of the tablet in the center above the battery.
    • Carefully insert the flat end of the blue plastic opening tool under the metal rectangular end of the back camera’s cable connector.
  8. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: adım 8, 1 resimden 1.
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the back camera’s metallic rectangular connector from its socket on the logic board.
  9. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: adım 9, 2 resimden 1. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: adım 9, 2 resimden 2.
    Satın Al
    • Squeeze the metallic rectangular piece with the tweezers to gently lift it from it's pit.
  10. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement, Battery: adım 10, 3 resimden 1. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement, Battery: adım 10, 3 resimden 2. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement, Battery: adım 10, 3 resimden 3.
    • Peel up the detachable corner of the white plastic sticker that reads “pull (hands only).”
    • Remove the sticker to form a tab.
  11. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: adım 11, 1 resimden 1.
    • Using your thumb and index finger, pinch the tab and pull it up to remove the top right corner of the battery from the front panel assembly.
    • If battery resistance is encountered due to adhesive, use the flat end of a spudger to run in between the battery and the front panel assembly.
    • Do not completely detach the battery just yet, doing so can cause damage to the red and blue cables loacted at the bottom of the battery.
  12. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: adım 12, 2 resimden 1. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: adım 12, 2 resimden 2.
    • Starting at the bottom left side of the battery, gently remove the green tape.
    • Salvage the green tape if the replacement battery does not include one.
  13. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: adım 13, 3 resimden 1. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: adım 13, 3 resimden 2. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: adım 13, 3 resimden 3.
    • Run the spudger under the battery to disconnect the red and blue cable connector from the circuit.
    • Lift the battery towards you, away from the front panel.
  14. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement, Motherboard: adım 14, 3 resimden 1. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement, Motherboard: adım 14, 3 resimden 2. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement, Motherboard: adım 14, 3 resimden 3.
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the metallic rectangular connector from its socket on the mother board.
  15. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: adım 15, 3 resimden 1. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: adım 15, 3 resimden 2. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: adım 15, 3 resimden 3.
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the gold rectangular connector from its socket on the mother board.
  16. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: adım 16, 3 resimden 1. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: adım 16, 3 resimden 2. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: adım 16, 3 resimden 3.
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the gold square connector from its socket on the mother board.
  17. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: adım 17, 3 resimden 1. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: adım 17, 3 resimden 2. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: adım 17, 3 resimden 3.
    • Using the spudger gently wedge the blue wire out of its compartment.
  18. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: adım 18, 1 resimden 1.
    • Remove two 2 mm #000 Phillips screws securing the metallic charger port cover to both the logic board and the front panel.
  19. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: adım 19, 3 resimden 1. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: adım 19, 3 resimden 2. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: adım 19, 3 resimden 3.
    Satın Al
    • Squeeze the metal charger port cover piece with the tweezers to gently lift it from it's place.
  20. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: adım 20, 3 resimden 1. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: adım 20, 3 resimden 2. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: adım 20, 3 resimden 3.
    • Carefully insert the flat end of the blue plastic opening tool under the black plastic fastener and lift.
    • Rotate your tablet counter clockwise to facilitate the process.
  21. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: adım 21, 2 resimden 1. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: adım 21, 2 resimden 2.
    • Squeeze the golden cable with the tweezers and gently pull the cable to the left to free the end of the golden cable.
    • The golden cable is delicate so use gentle force.
  22. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: adım 22, 1 resimden 1.
    • Remove three 2 mm #000 Phillips screws securing the mother board to the front panel.
  23. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: adım 23, 2 resimden 1. Samsung Galaxy Tab 4 8.0 Verizon Motheboard Replacement: adım 23, 2 resimden 2.
    • Using your hands, hold the opposite ends of the mother board corners, and lift.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Ofelia Cruz
1.119 İtibar
5 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team 1-3, Bruce Fall 2015 CSU Fullerton, Team 1-3, Bruce Fall 2015 üyesi
CSUF-BRUCE-F15S1G3
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 16
Her zaman: 2,719
