Ana içeriğe geç
Samsung Galaxy Tab 4 8.0 Verizon Rear Case Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Tab 4 8.0 Verizon Rear Case Replacement, Rear Case: adım 1, 3 resimden 1. Samsung Galaxy Tab 4 8.0 Verizon Rear Case Replacement, Rear Case: adım 1, 3 resimden 2. Samsung Galaxy Tab 4 8.0 Verizon Rear Case Replacement, Rear Case: adım 1, 3 resimden 3.
    • Before disassembling your Samsung Galaxy Tab 4 8.0, be sure it is powered off and you remove the SIM and Micro SD cards.
    • At the top of the tablet, nudge the blue plastic opening tool between the back plastic casing and the front panel's metal rim.
    • Do not use excessive force when prying the clips, fastening the casing together, open because they can easily break.
  2. Samsung Galaxy Tab 4 8.0 Verizon Rear Case Replacement: adım 2, 2 resimden 1. Samsung Galaxy Tab 4 8.0 Verizon Rear Case Replacement: adım 2, 2 resimden 2.
    • Continue prying the blue plastic opening tool along the perimeter of the tablet to separate the back plastic casing from the front assembly panel.
    • As right-handers, we found it easiest to move clockwise and use more pressure around the corners to facilitate the process.
    • You might hear several popping noises caused by the plastic clips coming undone.
  3. Samsung Galaxy Tab 4 8.0 Verizon Rear Case Replacement: adım 3, 2 resimden 1. Samsung Galaxy Tab 4 8.0 Verizon Rear Case Replacement: adım 3, 2 resimden 2.
    • To avoid damaging the screen, gently set the tablet with the LCD screen faced down.
    • Firmly grasp the back plastic casing and lift it away from the front assembly panel.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ofelia Cruz
1.119 İtibar
5 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team 1-3, Bruce Fall 2015 CSU Fullerton, Team 1-3, Bruce Fall 2015 üyesi
CSUF-BRUCE-F15S1G3
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 12
Her zaman: 903
