Ana içeriğe geç
Samsung Galaxy Tab 4 8.0 Verizon Speaker Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement, Motherboard: adım 1, 3 resimden 1. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement, Motherboard: adım 1, 3 resimden 2. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement, Motherboard: adım 1, 3 resimden 3.
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the metallic rectangular connector from its socket on the mother board.
  2. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: adım 2, 3 resimden 1. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: adım 2, 3 resimden 2. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: adım 2, 3 resimden 3.
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the gold rectangular connector from its socket on the mother board.
  3. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: adım 3, 3 resimden 1. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: adım 3, 3 resimden 2. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: adım 3, 3 resimden 3.
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the gold square connector from its socket on the mother board.
  4. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: adım 4, 3 resimden 1. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: adım 4, 3 resimden 2. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: adım 4, 3 resimden 3.
    • Using the spudger gently wedge the blue wire out of its compartment.
  5. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: adım 5, 1 resimden 1.
    • Remove two 2 mm #000 Phillips screws securing the metallic charger port cover to both the logic board and the front panel.
  6. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: adım 6, 3 resimden 1. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: adım 6, 3 resimden 2. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: adım 6, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Squeeze the metal charger port cover piece with the tweezers to gently lift it from it's place.
  7. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: adım 7, 3 resimden 1. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: adım 7, 3 resimden 2. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: adım 7, 3 resimden 3.
    • Carefully insert the flat end of the blue plastic opening tool under the black plastic fastener and lift.
    • Rotate your tablet counter clockwise to facilitate the process.
  8. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: adım 8, 2 resimden 1. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: adım 8, 2 resimden 2.
    • Squeeze the golden cable with the tweezers and gently pull the cable to the left to free the end of the golden cable.
    • The golden cable is delicate so use gentle force.
  9. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: adım 9, 1 resimden 1.
    • Remove three 2 mm #000 Phillips screws securing the mother board to the front panel.
  10. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: adım 10, 2 resimden 1. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: adım 10, 2 resimden 2.
    • Using your hands, hold the opposite ends of the mother board corners, and lift.
  11. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement, Speaker: adım 11, 1 resimden 1.
    • Insert the opening tool tip into the crack between the speaker and device.
  12. Samsung Galaxy Tab 4 8.0 Verizon Speaker  Replacement: adım 12, 1 resimden 1.
    • Gently pry up on the speaker to disconnect the speaker from the device.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 144
