Ana içeriğe geç
Samsung Galaxy Tab 4 8.0 Wi-Fi Rear Case Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Tab 4 8.0 Wi-Fi Rear Case Replacement, Rear Case: adım 1, 1 resimden 1.
    • Before you being the replacement process, make sure the tablet is completely powered off.
    • Gently insert the plastic opening tool between the metal rim and the back plastic casing at the bottom of the tablet and pry the back casing away from the device. Continue to separate the back panel of the device from the front assembly.
    • Right-handed users will probably be more comfortable prying in a clockwise movement, while left-handed users will feel more comfortable doing a counter clockwise movement.
    • When taking off the rear case there will be periodic clicking noises. Do not worry about those noises. They are just the rear case being disconnected.
    • Be careful not to use too much force as the plastic clips can easily be broken.
  2. Samsung Galaxy Tab 4 8.0 Wi-Fi Rear Case Replacement: adım 2, 1 resimden 1.
    • Place the tablet screen down on a clean surface.
    • Grasp the back panel and lift it from the device.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Cameron Morrow
384 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 25-3, Maness Spring 2016 Cal Poly, Team 25-3, Maness Spring 2016 üyesi
CPSU-MANESS-S16S25G3
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 11
Her zaman: 642
