Ana içeriğe geç
Samsung Galaxy Tab 4 Motherboard Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Tab 4 Motherboard Replacement, Motherboard: adım 1, 2 resimden 1. Samsung Galaxy Tab 4 Motherboard Replacement, Motherboard: adım 1, 2 resimden 2.
    • Insert the plastic opening tool into the gap between the device frame and the back panel on any side of the device.
    • Slide the opening tool around the edges of the device to disconnect the back panel from the frame.
  2. Samsung Galaxy Tab 4 Motherboard Replacement: adım 2, 3 resimden 1. Samsung Galaxy Tab 4 Motherboard Replacement: adım 2, 3 resimden 2. Samsung Galaxy Tab 4 Motherboard Replacement: adım 2, 3 resimden 3.
    • Carefully remove the back panel from the frame of the device.
  3. Samsung Galaxy Tab 4 Motherboard Replacement: adım 3, 3 resimden 1. Samsung Galaxy Tab 4 Motherboard Replacement: adım 3, 3 resimden 2. Samsung Galaxy Tab 4 Motherboard Replacement: adım 3, 3 resimden 3.
    • Using a Phillips #00 Screwdriver, remove the five 4 mm screws connecting the motherboard to the frame of the device.
  4. Samsung Galaxy Tab 4 Motherboard Replacement: adım 4, 3 resimden 1. Samsung Galaxy Tab 4 Motherboard Replacement: adım 4, 3 resimden 2. Samsung Galaxy Tab 4 Motherboard Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Use the plastic opening tool to unlock the battery wire from the motherboard by flipping-up the small retaining flap.
    • Use the tweezers to carefully remove the battery wire from the motherboard by pulling it away from the retainer flap.
  5. Samsung Galaxy Tab 4 Motherboard Replacement: adım 5, 3 resimden 1. Samsung Galaxy Tab 4 Motherboard Replacement: adım 5, 3 resimden 2. Samsung Galaxy Tab 4 Motherboard Replacement: adım 5, 3 resimden 3.
    • Use the plastic opening tool to unlock the wire on the narrow section of the motherboard by flipping-up the retaining flap.
    • Use the tweezers to carefully remove the wire from the motherboard by sliding it away from the retaining flap.
  6. Samsung Galaxy Tab 4 Motherboard Replacement: adım 6, 3 resimden 1. Samsung Galaxy Tab 4 Motherboard Replacement: adım 6, 3 resimden 2. Samsung Galaxy Tab 4 Motherboard Replacement: adım 6, 3 resimden 3.
    • Disconnect the wire near the bottom of the motherboard by placing the plastic opening tool under the edge of the connector to flip it up.
  7. Samsung Galaxy Tab 4 Motherboard Replacement: adım 7, 3 resimden 1. Samsung Galaxy Tab 4 Motherboard Replacement: adım 7, 3 resimden 2. Samsung Galaxy Tab 4 Motherboard Replacement: adım 7, 3 resimden 3.
    • Disconnect the wire near the top of the motherboard by placing the plastic opening tool under the edge of the connector to flip it up.
  8. Samsung Galaxy Tab 4 Motherboard Replacement: adım 8, 3 resimden 1. Samsung Galaxy Tab 4 Motherboard Replacement: adım 8, 3 resimden 2. Samsung Galaxy Tab 4 Motherboard Replacement: adım 8, 3 resimden 3.
    • Gently remove the motherboard from the frame of the device by grabbing the top and bottom ends and pulling it toward you.
    • Several plastic tabs keep the motherboard in place, so you will have to apply some force.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Peter Oliver
227 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 18-3, Forte Fall 2016 Cal Poly, Team 18-3, Forte Fall 2016 üyesi
CPSU-FORTE-F16S18G3
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 1,724
