1. Using the prying tool, pry the silver binding from around tablet from glass edge. You will need to go around the device several times applying some force before it comes off. Using the prying tool, pry the silver binding from around tablet from glass edge. You will need to go around the device several times applying some force before it comes off. Using the prying tool, pry the silver binding from around tablet from glass edge. You will need to go around the device several times applying some force before it comes off.
    • Using the prying tool, pry the silver binding from around tablet from glass edge. You will need to go around the device several times applying some force before it comes off.
  2. Detach the five wire connection of the battery from the motherboard. You will need to gently insert a flat head screwdriver under the connector, and using left to right motion with your wrist, create a small space separating the connector from its connection. Gradually make the space wider until the connector pops out of its socket.
    • Detach the five wire connection of the battery from the motherboard. You will need to gently insert a flat head screwdriver under the connector, and using left to right motion with your wrist, create a small space separating the connector from its connection. Gradually make the space wider until the connector pops out of its socket.
  3. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  4. Remove the 6 screws securing battery.
    • Remove the 6 screws securing battery.
  5. Remove the original battery, replace it with a new one.
    • Remove the original battery, replace it with a new one.
Sonuç
6 başka kişi bu kılavuzu tamamladı.
Stephanie Wong
919 İtibar
5 adet Kılavuz yazıldı
Takım
USF Tampa, Team 13-2, Staggers Fall 2014 USF Tampa, Team 13-2, Staggers Fall 2014 üyesi
USFT-STAGGERS-F14S13G2
4 Üyeler
9 adet Kılavuz yazıldı
Bir Yorum
Awesome Guide. I see that the only replacement battery offered here is used. If you are looking for a new replacement battery here is one that comes with the needed installation tools: http://www.mpfproducts.com/samsung-galax...
Mike - Yanıt
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 9
Son 30 Gün: 42
Her zaman: 6,317
