Ana içeriğe geç
Samsung Galaxy Tab 7.7 Flex cable Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Tab 7.7 Flex cable Replacement, Opening the tablet: adım 1, 3 resimden 1. Samsung Galaxy Tab 7.7 Flex cable Replacement, Opening the tablet: adım 1, 3 resimden 2. Samsung Galaxy Tab 7.7 Flex cable Replacement, Opening the tablet: adım 1, 3 resimden 3.
    • Using the prying tool, pry the silver binding from around tablet from glass edge. You will need to go around the device several times applying some force before it comes off.
  2. Samsung Galaxy Tab 7.7 Flex cable Replacement, Disconnecting the flex cable: adım 2, 2 resimden 1. Samsung Galaxy Tab 7.7 Flex cable Replacement, Disconnecting the flex cable: adım 2, 2 resimden 2.
    • Unsnap all the ribbon cables from the flex cable.
  3. Samsung Galaxy Tab 7.7 Flex cable Replacement, Unscrewing the flex cable: adım 3, 1 resimden 1.
    • Remove the screws securing the flex cable to the chassis.
  4. Samsung Galaxy Tab 7.7 Flex cable Replacement, Removing the flex cable: adım 4, 2 resimden 1. Samsung Galaxy Tab 7.7 Flex cable Replacement, Removing the flex cable: adım 4, 2 resimden 2.
    • Remove the original flex cable and replace it with the flex cable.
Sonuç
Stephanie Wong
973 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 13-2, Staggers Fall 2014 USF Tampa, Team 13-2, Staggers Fall 2014 üyesi
USFT-STAGGERS-F14S13G2
4 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 830
