Ana içeriğe geç
Samsung Galaxy Tab 7.7 Rear Facing Camera Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Tab 7.7 Rear Facing Camera Replacement, Opening the tablet: adım 1, 3 resimden 1. Samsung Galaxy Tab 7.7 Rear Facing Camera Replacement, Opening the tablet: adım 1, 3 resimden 2. Samsung Galaxy Tab 7.7 Rear Facing Camera Replacement, Opening the tablet: adım 1, 3 resimden 3.
    • Using the prying tool, pry the silver binding from around tablet from glass edge. You will need to go around the device several times applying some force before it comes off.
  2. Samsung Galaxy Tab 7.7 Rear Facing Camera Replacement, Disconnecting the camera: adım 2, 1 resimden 1.
    • Detach the ribbon cable from the flex cable.
  3. Samsung Galaxy Tab 7.7 Rear Facing Camera Replacement, Removing the flex cable: adım 3, 1 resimden 1.
    • Detach all ribbon cables from the flex cable, unscrew the flex cable, and remove the flex cable. This needs to be done in order to remove the camera which sits underneath the flex cable.
  4. Samsung Galaxy Tab 7.7 Rear Facing Camera Replacement, Removing the camera: adım 4, 1 resimden 1.
    • Replace the original camera with the new camera. It should come right out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Stephanie Wong
973 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 13-2, Staggers Fall 2014 USF Tampa, Team 13-2, Staggers Fall 2014 üyesi
USFT-STAGGERS-F14S13G2
4 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 661
