Ana içeriğe geç
Samsung Galaxy Tab 8.9 Motherboard Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Tab 8.9 Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Insert a plastic opening tool between the back cover and the screen of the Samsung Galaxy Tab 8.9.
  2. Samsung Galaxy Tab 8.9 Motherboard Replacement: adım 2, 1 resimden 1.
    • 6 cm [2 in] away from the first plastic opening tool, insert a second plastic opening tool between the back cover and the screen.
  3. Samsung Galaxy Tab 8.9 Motherboard Replacement: adım 3, 1 resimden 1.
    • Slide the second plastic opening tool along the edge of the device to separate the back cover from the screen.
  4. Samsung Galaxy Tab 8.9 Motherboard Replacement: adım 4, 1 resimden 1.
    • Use your hands to open the back cover.
  5. Samsung Galaxy Tab 8.9 Motherboard Replacement, Remove Green Tape: adım 5, 3 resimden 1. Samsung Galaxy Tab 8.9 Motherboard Replacement, Remove Green Tape: adım 5, 3 resimden 2. Samsung Galaxy Tab 8.9 Motherboard Replacement, Remove Green Tape: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Use tweezers to peel up the green tape located on top of the two flexible ribbon cables.
  6. Samsung Galaxy Tab 8.9 Motherboard Replacement: adım 6, 2 resimden 1. Samsung Galaxy Tab 8.9 Motherboard Replacement: adım 6, 2 resimden 2.
    • Insert a spudger under the orange tab.
    • Gently pry up the tab to disconnect the black flexible ribbon cable from the motherboard.
  7. Samsung Galaxy Tab 8.9 Motherboard Replacement: adım 7, 3 resimden 1. Samsung Galaxy Tab 8.9 Motherboard Replacement: adım 7, 3 resimden 2. Samsung Galaxy Tab 8.9 Motherboard Replacement: adım 7, 3 resimden 3.
    • Carefully pull out the yellow flexible ribbon cable to disconnect it from the motherboard.
  8. Samsung Galaxy Tab 8.9 Motherboard Replacement, Disconnect Battery from MotherBoard: adım 8, 3 resimden 1. Samsung Galaxy Tab 8.9 Motherboard Replacement, Disconnect Battery from MotherBoard: adım 8, 3 resimden 2. Samsung Galaxy Tab 8.9 Motherboard Replacement, Disconnect Battery from MotherBoard: adım 8, 3 resimden 3.
    • Insert the spudger under the red, black, and white cables.
    • Pry up and detach the battery from the motherboard.
  9. Samsung Galaxy Tab 8.9 Motherboard Replacement: adım 9, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the nine 1 mm screws located around the battery.
  10. Samsung Galaxy Tab 8.9 Motherboard Replacement, Remove the Battery: adım 10, 3 resimden 1. Samsung Galaxy Tab 8.9 Motherboard Replacement, Remove the Battery: adım 10, 3 resimden 2. Samsung Galaxy Tab 8.9 Motherboard Replacement, Remove the Battery: adım 10, 3 resimden 3.
    • Use a spudger to lift up and separate the battery from its housing.
  11. Samsung Galaxy Tab 8.9 Motherboard Replacement, Motherboard: adım 11, 3 resimden 1. Samsung Galaxy Tab 8.9 Motherboard Replacement, Motherboard: adım 11, 3 resimden 2. Samsung Galaxy Tab 8.9 Motherboard Replacement, Motherboard: adım 11, 3 resimden 3.
    • Locate the motherboard and 5 connectors on it.
    • Pry up and detach the connector from the motherboard using the flat edge of the spudger.
    • Repeat for the 4 remaining connectors.
  12. Samsung Galaxy Tab 8.9 Motherboard Replacement: adım 12, 3 resimden 1. Samsung Galaxy Tab 8.9 Motherboard Replacement: adım 12, 3 resimden 2. Samsung Galaxy Tab 8.9 Motherboard Replacement: adım 12, 3 resimden 3.
    • Using the Phillips #00 screwdriver, unscrew the 3 screws (1mm) that are located near:
    • Camera
    • Power and volume buttons
    • Tilt sensor
  13. Samsung Galaxy Tab 8.9 Motherboard Replacement: adım 13, 3 resimden 1. Samsung Galaxy Tab 8.9 Motherboard Replacement: adım 13, 3 resimden 2. Samsung Galaxy Tab 8.9 Motherboard Replacement: adım 13, 3 resimden 3.
    • Using the flat edge of the spudger, pry and lift up the motherboard.
  14. Samsung Galaxy Tab 8.9 Motherboard Replacement: adım 14, 2 resimden 1. Samsung Galaxy Tab 8.9 Motherboard Replacement: adım 14, 2 resimden 2.
    • Pull away the motherboard from the housing.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Aleezee True
532 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 11-4, Blackwell Fall 2014 USF Tampa, Team 11-4, Blackwell Fall 2014 üyesi
USFT-BLACKWELL-F14S11G4
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 2,326
