Ana içeriğe geç
Samsung Galaxy Tab A 10.1 Back Panel Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Tab A 10.1 Back Panel Replacement, Back Panel: adım 1, 2 resimden 1. Samsung Galaxy Tab A 10.1 Back Panel Replacement, Back Panel: adım 1, 2 resimden 2.
    • Have the front of the device facing you.
    • Begin near one of the curved edges of the device (see photo two for visual example).
    • Place a plastic opening tool between the front and back panels.
    • If a plastic opening tool doesn’t work, using a metal spudger may work, but it may damage the plastic on the device.
    • Remember to remove the micro SD card (if present) before you begin.
  2. Samsung Galaxy Tab A 10.1 Back Panel Replacement: adım 2, 2 resimden 1. Samsung Galaxy Tab A 10.1 Back Panel Replacement: adım 2, 2 resimden 2.
    • Once the plastic opening tool is fully inserted, wedge it around the device’s edges to separate the panels.
    • Lift the back panel off of the device.
    • The back panel will make a clicking noise while being lifted off of the device.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Isabella Li
2.376 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S15-G6, Livingston Fall 2017 Cal Poly, Team S15-G6, Livingston Fall 2017 üyesi
CPSU-LIVINGSTON-F17S15G6
4 Üyeler
26 adet Kılavuz yazıldı
Bir Yorum
Why need to remove cables when only the back has to be replaced ?
nabe_03 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 21
Son 30 gün: 86
Her zaman: 11,934
